how to update sky+ help
Discussion in 'Sky Digital TV Forum' started by bart750, Mar 11, 2005.
  1. bart750
    bart750
    Jul 1, 2004
    239
    barnsley
    how do force the sky +box to update as it hasent been used for a long time its a new shape pace all silver thanks chris
  2. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,397
    Bradford, West Yorkshire.
    +325
    do search you find answer question
  3. dubledene
    dubledene
    take out the power cable then re insert it whilst holding the back up button on the front of the digibox hold it in till it starts
  4. bart750
    bart750
    Jul 1, 2004
    239
    barnsley
    thanx will try it now chhhhhhhhhhhhhers
  5. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Always better to switch it off at the plug, removing and replacing a live power cord will cause some arcing, perhaps not a big issue but with SKY hardware why take the chance:)
  6. bart750
    bart750
    Jul 1, 2004
    239
    barnsley
    ok thanxs all done and updated
