Quantcast
How to test whether a LED/LCD tv supports both NTSC and PAL ?
NX3
Most panels these days support both formats. Not sure what your trying to prove, a simple test would be to feed a PAL signal, does it display ? Same for NTSC
Mark uk
If you are in UK I would say almost definately yes, If you are in US then its more of a 50/50.
iaint
Hi.
Laptops and cheap DVD players can often be set to output either PAL or NTSC signal. If it displays, looks good.
Tech specs part of the manual would normally also say.
Regards, Iain.
Similar threads
