mark25810
Hi there i hope someone can help me, i have ordered a mega drive from ebay and need one of those rgb scart leads for it, i have a samsung syncmaster 510mp which has rgb scart but i also wanted to use my CRT its a orion tv134r.
I can not tell if the scart is RGB the box states just EURO scart and the manual just says select the AV channel when using scart and press 0/AV button
That is all it says. i do not have any scarts or RGB devices to test it but if i order one of these cables i may not be able to return it if its my tv that is the issue.
Also if i did buy one and my tv scart is not RGB will it still work or will it show the picture in black and white, i am a total noob with some things like this.
I am aware you can get the AV scart wires for the mega drive but i wanted one of the RGB ones for best picture and stereo sound
