How to switch between custom resloutions in powerstrip
Discussion in 'Desktop & Laptop Computers Forum' started by Spacecat, Dec 22, 2004.
  1. Spacecat
    Spacecat
    Apr 1, 2001
    3,332
    London
    +952
    Can anyone tell me how to set up a quick hot key set up for switching between 2 resolutions in powerstrip
    one 680x480 @50hz and one 680x480 @60 hz
    i need to be able to switch between the 2 without looking at the screen
    i.e. just keyboard.
    any help appreciated muchly!!
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    set up your resolutions
    go to options in powerstrip , hotkeys.
    associate whatever binding you want with each res.
    I use CTRL-ALT P and CTRL-ALT R , best you don't use any of the standard windows ones obviously (CTRL-ALT delete for example)
    It was a doddle.
  3. Spacecat
    Spacecat
    Apr 1, 2001
    3,332
    London
    +952
    cheers im quite new to powerstrip so its a bit confusing
    Also is it possoble to set up 2 different resolutions and refresh rates on a dual head card and out put at the same time?
  4. Muf
    Muf
    Sep 11, 2003
    412
    IRL
    +8
    Keith, Spacekat needs the same resolution for both profiles just different refresh rates and there is a problem with that in powerstrip. There is a solution, read the last post on the following thread by myself.
    http://www.avforums.com/forums/showthread.php?t=160436
    Jim.
  5. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    ah nice one.
