How to stream (without recording) to a JVC 30k?
Discussion in 'General TV Discussions Forum' started by nurfen, May 17, 2004.
  1. nurfen
    nurfen
    I've got a JVC 30k DVHS recorder, and I'm wondering how to do when I want to send a stream (.ts?) via firewire, without recording anything on the JVC. I just want it to send the (decoded?) signal to the projector via component.
    I've got DVHS Tool, is it possible with this program?
    /Fredrik
  2. pdundas
    pdundas
    Yes, it's quite possible. Just set the VCR to the correct I-link (Firewire) channel, start the stream and don't hit record.
    You need to ensure that "Control Tape Transport" is not selected in DVHStool.
  3. nurfen
    nurfen
    Thanks for your answer.
    What's the firewire channel?
  4. pdundas
    pdundas
    Once it's connected up, press the down channel until it says "I-" in the channel display. Once synced up the JVC will automatically be assigned a number on the Firewire bus so it will say "I-1, I-2, I-3 etc." or whatever it has assigned.
    I've had mixed results with DVHStool and combinations of 30k/40k. On some streams it works fine but with others the stream shows errors. There are also various versions of DVHStool and you might want to try a few to see which gives your particual combination the best results.
  5. pdundas
    pdundas
    One other thing: You can usually tell it's set correctly to the firewire input as it will display "Auto" in the tape speed icon on the front display of the unit.
  6. nurfen
    nurfen
    Ok thank you. I'll it out.
