how to stop Q200 moving across floor?
Discussion in 'Subwoofers' started by Such, Jan 4, 2005.
  1. Such
    Such
    Dec 27, 2003
    2,058
    48
    Greenhithe
    +98
    Can anyone suggest suitable feet to place under my Q200 to stop it moving across my wooden floor. I currently have the supplied tiny plastic screw-ins with some rubber underneath, but it still manages to creak and shift whilst in use.
  2. RobsterD
    RobsterD
    Dec 11, 2000
    870
    Southampton
    +12
    Could you not place a nice big marble/slate slab on top,I currently run 2 q200e which are sandwiched by 2 marble slabs,they dont move now :)
    Rob
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I use 4 doorstops beneath my BK XLS200 which is of a very similar design, I've only tried this on carpet though.
    You could make a plinth of wood to put on the carpet, the sub won't move on the wood and the wood shouldn't move on the carpet as long as it's got some grain on it. Paint it black and it's camouflaged by the sub's own shadow :)
  4. Such
    Such
    Dec 27, 2003
    2,058
    48
    Greenhithe
    +98
    Rob, what feet have you got on your q2's? and do you have a slab underneath and on top? How much did they cost?
  5. RobsterD
    RobsterD
    Dec 11, 2000
    870
    Southampton
    +12
  6. Such
    Such
    Dec 27, 2003
    2,058
    48
    Greenhithe
    +98
    thanks for that. Very interesting. I got quoted around £100 just for two 30 by 30 slabs!
    This seems excessive. Would a few of the same sized floor tiles (10cm thick) stuck together do the same job?
  7. RobsterD
    RobsterD
    Dec 11, 2000
    870
    Southampton
    +12
    A cheap alternative which a few have tried is a standard concrete garden slab primed and painted in the colour of your choice,worth a punt
    Rob
  8. Such
    Such
    Dec 27, 2003
    2,058
    48
    Greenhithe
    +98
    managed to get 2 granite slabs 300x300x30mm and 3 rubber mats from atlanticrubber.co.uk The sub goes nowhere now and it does sound much tighter.
    Total cost £80. Looks much nicer too..according to the wife, so it cant be bad!
