How to stop LG RZ42PX11 switching inputs through scart?
Discussion in 'Plasma TVs' started by OkUThinkOfAName, Aug 1, 2005.
  1. OkUThinkOfAName
    OkUThinkOfAName
    Aug 18, 2003
    northern ireland
    Have a Toshiba RDXS32 DVD/HDD Recorder connected to my LG by scart with one annoying little problem.
    I use the PIP on the LG to allow me to set the video or delete content etc while not disturbing what someone is watching, but every time I do something on the video, the LG switches the input.
    Does anyone know how to stop this either by a setting on the LG or the Toshiba, I have been through the service menu on the LG but can`t see anything that might do this.
    The only other option I can think of is disconnecting the pin on the scart, but that would be a last ditch option.
  2. maverick52
    maverick52
    Jul 22, 2005
    249
    +11
    do you have more than one scart socket ? they may not all be fully switchable
  3. OkUThinkOfAName
    OkUThinkOfAName
    Aug 18, 2003
    northern ireland
    Hadn`t considered that, will try it, thanks.
  4. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
    Generally pin 8 on a scart cable carries the trigger voltage that your TV uses to 'decide' when to switch inputs. If you cut the cable on pin 8 inside the scart plug the TV will only switch AV inputs when asked.
    (Sorry, I posted this before reading your post fully)
  5. jedi-knight
    jedi-knight
    Nov 2, 2004
    842
    Llanelli
    +11
    the best way i found for sorting out problems with the lg px11 i had, was sending it back.
    :thumbsup:
