How to stop a ceiling pj falling on head...
Discussion in 'Home Cinema Building DIY' started by chilli, Oct 27, 2004.
  1. chilli
    chilli
    :hiya:
    Any help on this would be appreciated.
    I have just made a ceiling mount for my HS20, using ideas from other members. Its quite a straightforward and cheap design: B&Q 400mm x 60mm table leg, piece of cut mdf, and lots of nuts, bolts and washers.
    I have figured out most of the design issues, but would like to know what the best way to secure the projector to the mount. At the minute it will just be held by the bolts that screw directly into the pj, is that sufficient?
    Im thinking about tying a strong failsafe wire to connect the mount with the extendable leg structure of the pj.....it wouldnt be very healthy to the pj if it detached from the mount, but at least it wouldn't fall on head.
    Am I missing something obvious?
    I would post some pics but I dont yet know how to, but any comments on the above would be :smashin:
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    That's been good enough for my pj for the last two years or so.... and probably for lots of others too. If having a "fail-safe wire" is going to make you feel happier, by all means do it, but using the correct bolts for the mounting hole in the projector will do just fine.
    Sean.
  3. chilli
    chilli
    Thanks for the reassurance. I got some advice from beecee on his mount, and after he sent me the diagram I realised I wasnt using enough nuts! :suicide: Problem solved.
    If I figure out how to attach pictures Ill do that when its all up and running.
  4. Seahorse
    Seahorse
    Jul 28, 2002
    141
    Southampton, Hants
    +3
    3" woodscrews into the joist are more than enough here... :rolleyes:
  5. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,217
    UK.
    +2,758
    There are only 3 M6 (IIRC) screws that hold my pj to the 6mm mdf board that's attached to the DIY ceiling mount, and 4 wood screws holding the ceiling mount to the wooden batten in the ceiling. You'll find that that will be fine for something weighing around 10 to 15lbs, and probably more.
    If the pj has 'x' amount of fixings to hold it to the mount, then that is all you need.
    Gary.
  6. chilli
    chilli
    thanks for that. Its working a treat. :beer:
  7. dts_boy
    dts_boy
    Nov 26, 2001
    2,615
    Manchester suburbs...
    +178
    whats wrong with a bit of blu-tac or double sided sticky tape? :D
    on a serious note, pics would be good as soon may go down the same route (don't make me try blu-tac first :eek: )
  8. chilli
    chilli
    hope these pictures make things clearer.
    I suppose I should get round to taking the stickers off the leg.
  9. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,217
    UK.
    +2,758
    Good job Chili!
    Cheap but functional, and fully adjustable I take it? Can it be rotated easily and locked into place?
    Gary.
  10. chilli
    chilli
    Thanks Gary
    At the minute the whole thing is held by the plastic foot of the leg, which is quite sturdy and adjustable. I have unscrewed the foot, threaded it thru a piece of mdf, then tightened the foot back on. The MDF then lies over and screwed into the joists.
    I still have to put a cover plate of some kind where the mount goes into the ceiling, and the mount is too low, but I have yet to figure out the solutions. I was so keen to get the mount up I haven't really seen it through yet. The improvement in quality, without using the Sony side shot feature, is reassuring.
    The whole thing cost about £17, so i am very happy I didn't waste money on one at the shops.
    If you have any suggestions how to blend this mount tastefully with the surroundings I would be grateful. The PJ is in the bedroom so it has to be fairly discreet. The PJ will be moving closer to the ceiling so that will help.
    These forums save you money :smashin:
  11. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,217
    UK.
    +2,758
    I guess getting it as close to the ceiling as possible, shorten the adjusters to a minimum, and paint the mount the same colour as the ceiling. Try to hide the cables too. That can make a lot of difference.
    Gary.
  12. MikeRJ
    MikeRJ
    Oct 21, 2004
    229
    Plymouth
    The cables could quite easily be routed through the table leg by drilling suitably sized holes and fitting rubber grommets to protect the insulation.
  13. chilli
    chilli
    excellent points made....well noted.
    I suppose the mount isnt really finished yet, so I will incorporate those ideas into the design.
    thanks very much
  14. chilli
    chilli
    Well it took long enough to complete but here is my finished mount.
    Thanks to the above for their input.
  15. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,217
    UK.
    +2,758
  16. chilli
    chilli
    thanks for that.
    Merry Christmas to you and your family.
