how to spend £2000 (ish)
Discussion in 'General TV Discussions Forum' started by cheeseywang, Feb 12, 2003.
  1. cheeseywang
    cheeseywang
    Jan 26, 2003
    218
    over the blue moon
    The question is should I go for:
    a) a 42" rear projection set or
    b) a LCD projector and screen or
    c) a 42" plasma screen from Richer?
    The set up will be in a dedicated AV room (loft conversion) viewing position about 10 feet from the screen. What would you recommend? I plan to audition all three options but would appreciate a little guidance.
  2. nathan_silly
    nathan_silly
    1) You can get the Toshiba 50WT29B for £1860. Personally I prefer CRT over LCD.
    Each have their pros and cons, but with LCD and Plasma pixel death- I chose RPTV.
    3)- Budget Plasma, 42"
