How to show lamp usage for Sanyo Z2?
Discussion in 'Projectors, Screens & Video Processors' started by BenPremium, Jul 10, 2005.
  1. BenPremium
    BenPremium
    Nov 23, 2003
    329
    16
    I recently bought a 2nd hand Sanyo Z2 and was wondering if there was any way of getting it to display how many hours the lamp had done?
  2. BenPremium
    BenPremium
    Nov 23, 2003
    329
    16
    Doesn't matter, got it sorted now. Hold down power on button for 20 seconds :)
  3. therealijn
    therealijn
    Oct 14, 2004
    38
    Bannockburn
    That's right ! When the projector is running, press and hold down the power button for 20 seconds or so. Keep holding - It'll then show lamp useage details. Let go button when your done (it may in fact only show the details for 5 seconds or so) and the projector won't turn off, but will turn off when you try a normal power down sequence.
