How to show DivX subs with the HD745?
Discussion in 'Blu-ray & DVD Players & Recorders' started by McE, Feb 16, 2005.
  1. McE
    McE
    Jan 9, 2005
    230
    Luzern, Switzerland
    +8
    I know it is possible but I'm unable to do it...
    what subtitle formats are possible? languages? And how do they have to be on the disc? :lease:
    cheers
  2. aligamer
    aligamer
    Feb 4, 2004
    88
    9
    United Blighty
    Well depending on ur player of which sub format it supports - ones i tried are .srt and subrips formats - language is english for me - you just place the sub(s) into the root directory of the movie - make sure that it is the same name as the file too, ie: file1.avi, file1.srt, file2.avi, file2.srt and so on. Basically thats it, you just play the divx, enable subs on and all should be well. Good luck!
  3. McE
    McE
    Jan 9, 2005
    230
    Luzern, Switzerland
    +8
    Tnx mate! I forgot to turn the subtitles on... my stupid :D
    btw. for any DivX user with the samsung via DVI: You have to put it in 4:3 Mode to get the right picture format! :thumbsup:
  4. LordRPI
    LordRPI
    Hey guys, I should have a guide up on how to easily use subtitles in DivX Players.
    - David Wolstencroft
    DivX Team
  5. McE
    McE
    Jan 9, 2005
    230
    Luzern, Switzerland
    +8
    Where?
    btw. the HD745 shows the subtitles in a dark blue bar across the bottom of the screen... normal?
