how to share replays
Discussion in 'Xbox Forums' started by techmob, Dec 16, 2004.
  1. techmob
    techmob
    Dec 16, 2004
    1,270
    48
    +47
    hi there, i've noticed some sites that share their goals etc, how do they do it
    i want to be able to save the replays from my xbox to my pc so i can show people my goals etc
    thanks
  2. Pooon
    Pooon
    Dec 26, 2002
    7,345
    Canterbury, Kent
    +935
    I dunno mate, can't you ask on the sites that do it? and then come back and tell us!
  3. techmob
    techmob
    Dec 16, 2004
    1,270
    48
    +47
    i saw it on one of the links on this site, http://www.pesmoves.com/
    if i find out i'll let you know, same with anyone else please thanks
  4. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    I'm guessing this is the PC version and they have used FrAPS or something ? If its been captured on a console then yer I really want to know !
  5. techmob
    techmob
    Dec 16, 2004
    1,270
    48
    +47
    well there is a hardware addon you can get for the xbox which allows you to transfer replays to the pc, but another way i thought it might be possible, is with a capture card, stick a capture card in pc and capture whats on the tv through the xbox, hence saving the replays on the pc
  6. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    hardware addon option ? got a link ?
  7. stumpy_uk
    stumpy_uk
    Aug 11, 2003
    194
    In front of My PC
    +9
    Most of the people use a capture card on their PC to record the goals a few use the DV Camera to do it. There is no utility to export the goal so you need to capture it in some way. Cheapest way is to buy a TV card and just connect the Video Cable etc and capture as AVI.
  8. Pooon
    Pooon
    Dec 26, 2002
    7,345
    Canterbury, Kent
    +935
    Had a brainwave. Some DV camcorders have an analog input (mine has!) so in theory i could connect the camcorder to one of the spare scarts on the back of my tv, hit record, play the game, score loads of goals, upload them to my pc, and then try to work out how to get you guys to see them.
    I know nothing about web hosting so if anyone has the space or knowledge i'll glady email or messenger the files to you.
    I'll try it out tomorrow evening with a replay that i've got saved to see if it does work, so if anyone will be around tomorrow night for me to send the file to give me a shout.
  9. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    Id be happy to host a few goals on the site .. was thinking of having a goal of the wekk spot etc .. that we can all vote on ...
  10. Pooon
    Pooon
    Dec 26, 2002
    7,345
    Canterbury, Kent
    +935
    I've the process of getting the replay data to my camcorder(but at the moment i don't have a scart splitter that has an s-video connector, get tomorrow) so i've been testing it with my sky+ box. So i now have a 30ish second clip that is about 34mb(when i transfered via USB) and the same file at 192mb(via firewire), so who wants to post these on the net?(when i get the replay data), can i make them smaller(they're MPEG's)? etc etc etc! :)
  11. techmob
    techmob
    Dec 16, 2004
    1,270
    48
    +47
    yeah ud be better of compressing the video, probably converting it to divx, make the file size smaller, way to big as it is...
  12. Pooon
    Pooon
    Dec 26, 2002
    7,345
    Canterbury, Kent
    +935
    How do i do that then? what software will i need? it needs to be 'free' :devil: and where do i get it?
  13. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    You wont be able to use the scart on your tv. On most sets the scart sockets are for input only. An easy way to capture would be with a DVD recorder with RGB pass through.
    My Panny has it and I imagine most others do as well. Just plug the xbox into the rgb socket NTL is normally plugged into and you can record straight to DVD. Can then use Pinnacle studio or one of the many other utils you can get from vcdhelp.co.uk, Imesh etc to get the clip out of DVD format and into mpeg etc etc etc.
    Obviously you would need a DVD recorder but isnt all this more hastle than its worth ?
  14. Pooon
    Pooon
    Dec 26, 2002
    7,345
    Canterbury, Kent
    +935
    Not a problem, scart number 2 is in and out, its just i need the scart adaptor to make it work, which isn't a problem.
  15. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    yer as long as its only a few mbs each im happy to host
  16. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,927
    2
    Manchester
    +4,450
    Assuming you're using Windows XP, Windows Movie Maker 2.1 will do the trick for reducing the file size/changing format, and its free. (cheapskate :p )
  17. Pooon
    Pooon
    Dec 26, 2002
    7,345
    Canterbury, Kent
    +935
    Hmm, all my genius plans have failed to bear fruit. I won't go into details but it didnt work :mad: so plan b it is. This is plan B AVerTV Box 3 i'll be getting one proper cheap which i think will do the job (best bloody do) but i won't be getting it till the first week of Jan when i also plan to get one of these babies Samsung 172x so everything should be sorted in the new year :clap: :clap:
