How to setup LG LCD's remote for a set-top-box
Discussion in 'LG TVs Forum' started by kaserdar, Feb 3, 2009.
  1. kaserdar
    kaserdar
    Hello everyone,
    I have a LG LCD 22LG3050 TV and ADB 3800TW set-top-box. I want to control the set-top-box with the tv's remote. So i need to know how to configure the tv's remote for it. Couldnt find the info in the manual.
    Anyone knows?
    Thank you very much
  2. J4CK DANIELS
    J4CK DANIELS
    Aug 3, 2006
    1,483
    +231
    * Switch the Cinema System ON
    * Push the STB button on the remote
    * press MENU and MUTE at the same time for appprox 2 seconds
    * Enter the code
    * press MENU to store.
    not sure about the code itself, if it isn't in the manual perhaps try LG customer services? they should have a list of codes that may work for your STB
