How to set up separate home theater + karaoke system?
nafgnahz
Hi, I want to set up a media room with a home theater system PLUS a separate speaker for Karaoke (coz I read the high pitch voice from Karaoke singing may damage the home theater speakers). Also wanna put Xbox in the room too. Here is a list of equipment I'm planning to get:
  • projector + projector screen
  • Polk 5.1 home theater speaker system
  • AV receiver
  • separate Bose speaker for Karaoke
  • mixer + mic for Karaoke
I'm planning to have all the media sources coming from a computer. But i'm not sure how to set up the systems. Here are the plans I have:
OPTION 1:
Home theater:
  • computer -- [HDMI] -- projector
  • projector audio out -- [3.5 to RCA] -- receiver
  • receiver -- [stereo cable] -- home theater system
Xbox:
* similar to above, replace computer to Xbox
Karaoke:
  • computer -- [3.5 to RCA] -- mixer
  • mic -- [XLR] -- mixer
  • mixer -- [3.5 to 3.5 ??] -- Bose
OPTION 2:
Home theater / Xbox:
  • computer / Xbox -- [HDMI] -- receiver
  • receiver -- [HDMI] -- projector
Karaoke:
  • computer -- [HDMI] -- audio/video splitter
  • audio -- [3.5 to RCA] -- mixer
  • video -- [HDMI] -- projector
In each case, I'd turn off the receiver if using the Karaoke system.
Will any of these options work? Or is there a better way to set up the system? Appreciate any inputs.. Thanks!
ShanePJ
AVForums Sponsor
I suppose the first question should be how large is the room, which products do you already own and are you open to different options plus what kind of budget are you looking at?
nafgnahz
The room is about 15 x 19. I have purchased most of the equipment already, and I went with the budget line from Polk, got the T series.
ShanePJ
AVForums Sponsor
So, you've got the Polk's! What AV Receiver did you purchase to drive them and which projector are you looking to use
As for karaoke and damage, this will depend upon how loud you have the volume and believe it, the cheaper the electronics and partnering components you are using to create the sound, the more chance you have of causing unwanted damage regardless of whether it's karaoke or playing movies/music. As you have bought cheaper speakers, just don't turn the volume up so loud so it hurts your ears and I would expect it would work. Also what out for feedback which could cause unwanted damage regardless of volume
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
