how to set up an lg plasma tv
H
hughesneil
can anyone point me in the right direction to find some detailed instructions on how to set up the plasma correctly,mainly to iliminate the lip sync problem and the display problems with smoke/clouds etc, I find I am constanly altering the settings, which is annoying the rest of the family.:lease:
kjt2004
Established Member
try the following
PSM = User
CSM = Cool
XD = off
Contrast = 40
Brightness 60
Colour = 14
Sharpness = anything from 0 -10
hope that helps
stainway
Established Member
:thumbsup:
kjt2004 said:
try the following
PSM = User
CSM = Cool
XD = off
Contrast = 40
Brightness 60
Colour = 14
hope that helps
I would say:
PSM = User
CSM = Normal
XD = off
Contrast = 52-55
Brightness=50-52
Colour = 20-24
Sharpness = anything from 11-21
You can try with any THX DVD-Starwars etc..Use the THX optimaizer menu.
stainway
Established Member
XD=on or off-question of personal taste. I used for months and I loved it. Right now I don't use it. It's great to start with it-makes live easier indeed. I personally found that is easier to set all those DVE tests without the XD.
kjt2004
Established Member
Maw
Yes it is the hyped sales feature and to be honest it does work.
As stainway says its personal taste, When i have it on it makes everything look sharper and blacks blacker .
i just prefer the slightly softer feel with it off
Is 8K TV dead? Philips OLED+907, Pioneer LX505 AVR plus B&W 700 S3 Reviews & Visit + AV/HiFi News
