How to "set-up" again?
Discussion in 'AV Receivers & Amplifiers' started by scoobysnack, May 19, 2005.
  1. scoobysnack
    scoobysnack
    Feb 12, 2002
    24
    Lymington,Hampshire
    I have just bought a Denon AVR2802 receiver second hand and when i press setup on the remote nothing happens. I assume this is because the previous owner would of used it to setup his system and therefore it thinks it's done. How do i re-set it or what do i do so i can set it up for my system not the previous owners?
    SS :confused:
  2. mjn
    mjn
    May 24, 2001
    22,122
    Herts, England
    +9,879
    Probably need to reset the unit, check the manual for the correct sequence of key presses.
  3. scoobysnack
    scoobysnack
    Feb 12, 2002
    24
    Lymington,Hampshire
    Have looked in manual and all it talks about is an initialisation of the microprocessor and clearing of learned remote control signals. Both of these i have done and it still hasn't made a difference.
    SS
  4. Miniholic
    Miniholic
    Apr 26, 2001
    3,054
    The Shire
    +398
    What connection are you using between the amp and your display? Some amps only output the onscreen display through certain connections. Failing that, it could be that the setup button on the remote is at fault.
    Setup isn't usually a one time only thing, as receivers need to be adjusted when other elements of the system are changed.
