how to set sky+ back to factory settings please?
Discussion in 'Sky Digital TV Forum' started by evilash, Jul 9, 2004.
  1. evilash
    evilash
    Dec 11, 2002
    795
    brighton
    +27
    please can someone help me with resetting the sky+ box as i am having trouble cycling through the faves links.... thanks in advance.....
    p.s. i have tried leaving everything unplugged including taking batteries out of remote for 20 mins +..
  2. Fernsehman
    Fernsehman
  3. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    press services on the remote
    select system set up
    press 1 then select should bring up another menu
    select full system reset
    you will loose all the planner contents including series links for futue programmes as well as any recorded programmes
  4. evilash
    evilash
    Dec 11, 2002
    795
    brighton
    +27
    thanks for the advice guys.. have tried everything that you have posted and also a couple of other things. i have finally conceded and called the shop i bought it from. they are coming to collect on monday and hopefully will sort it out that way... thanks again though.....
