How to set region on Pan E85H
Discussion in 'Blu-ray & DVD Players & Recorders' started by peck2000, Jun 14, 2004.
  1. peck2000
    peck2000
    I've just bought a multi-region Panasonic DMR-E85H. However, my current Marantz Player occasionally tells me that it can't play a certain DVD and asked me to manually change the region.
    Is there a manual region changing facility on the multi-region version of the E85H that anyone knows of?
    I'm concerned that I'll try to watch a region 3 and the multi-region facility on the E85H won't be able to handle it . . .
    Peck2000
  2. AV Geeza
    AV Geeza
    Oct 10, 2001
    397
    Londinium
    +3
    Ive watched regions 1,2 & 3 with no problems so far.
    The E85 will auto switch to which ever region the dvd is.
  3. peck2000
    peck2000
    OK - that's good news . . .
    But what about the dreaded Enhanced Region Coding? Disks with ERC are the ones that have always given me trouble in the past, sometimes found with Region 1 disks but mostly with Region 3 - like the recent Shaw Brothers DVDs available from CD-Wow . . .
    Peck2000
