How to screw a Noctua NF-S12-800 to a Nitrogon NT06 heatsink?
Discussion in 'Desktop & Laptop Computers Forum' started by gvh, Sep 6, 2007.
  1. gvh
    gvh
    May 16, 2002
    217
    Southampton
    +20
    I've just bought these 2 from mediapc.tv and the screws with the NT06 are too short to go right through the fan holes and reach the metal.
    I don't see how I can use the squidgy things that come with the Noctua and Jason is on holiday or I'd ask him
    Any thoughts?
    thanks a lot
  2. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    Th rubber mounts are easy to use, but they might be too short for what you need if the normal screws wont reach. Best bet is to get longer screws from an electrical or diy store.
  3. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
  4. gvh
    gvh
    May 16, 2002
    217
    Southampton
    +20
    Yes, this is it. It comes with screws that are not long enough to go through the fan. I guess I'll be rumaging around a diy store and having to buy a pack of 50 or something...
  5. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    When you install the fan there should be some small rubber/foam strips. Place these between the fan and the heatsink. This will stop vibration being transmitted from the fan through to the heatsink. If there arent any try and get some yourself. :)
  6. gvh
    gvh
    May 16, 2002
    217
    Southampton
    +20
    Solved,
    a very nice man in the computer shop (teknophobic.co.uk) in the bottom of the bargate shopping centre of southampton gave me two screws. He wouldn't take any money either.
    Thanks for your replies
    Gareth
