How to reset the color on a Samsung UE55 F8000 ?
sweetaz
Can anyone please tell me how to reset the colour settings in the service menu of a Samsung UE55 F8000.
I clicked on something in there and now my TV colour is all messed up. I've tried resetting the colour in the TV menu
but it didn't help much. Thank you
notengo13
REMEMBER once you enter to Service Menu you can easily brick your TV and always take fotos or record video with values you see there because if you change something TV won't ask you if you want to apply changes.
check what TYPE you have in Service Menu and Front Color
TYPE should be 55A2UF8E
for Front Color you have to check youtube and hope there is somebody with your exact TV showing service menu.
good luck
sweetaz
good luck
@notengo13 Thanks very much for your help. I went into the service menu to see if I could fix an HDMI problem and clicked on something by mistake.The HDMI ports are seeing my firestick opening page then the resolution changes and it says no signal. Could that be something to do with the EDID? I found the service manual online after searching for a while so hopefully that will help. I've taken photos of all the menus and sub menus in the service menu so hopefully that prevent future problems. Thanks again for your advice.
sweetaz
@notengo13
I checked the type and that was the same as you mentioned which is good - 55A2UF8E.
I tried to change the front color but I don't have U-MOIP as an option in the service menu.
The only options I have are:
None
P-W-D-40
P-W-D-49
P-W-D-55
P-W-D-85
U-S-C-5K
U-T-CL-M61
U-T-WG-M63
U-T-CL-M64
U-T-WG-M64
U-T-CL-M65
U-T-CL-M67
U-T-CL-M68
U-T-CL-M71
U-T-CL-V75
U-T-CL-B75
U-CF-B80
U-CF-B80-75
U-CF-B85
UHF-85
U-T-CL-M61-6
U-TC-V7160
U-T-CL-V7560
U-CF-B80-60
U-CF-B80-65
U-CF-B82-75
N/A
Should I try the factory reset or is it best to leave that alone?
notengo13
@notengo13
None
P-W-D-40
P-W-D-49
P-W-D-55
P-W-D-85
U-S-C-5K
U-T-CL-M61
U-T-WG-M63
U-T-CL-M64
U-T-WG-M64
U-T-CL-M65
U-T-CL-M67
U-T-CL-M68
U-T-CL-M71
U-T-CL-V75
U-T-CL-B75
U-CF-B80
U-CF-B80-75
U-CF-B85
UHF-85
U-T-CL-M61-6
U-TC-V7160
U-T-CL-V7560
U-CF-B80-60
U-CF-B80-65
U-CF-B82-75
N/A
Factory reset won't reset service menu to its default.
What value you had on front color?
sweetaz
I tried all of them one at a time but it didn't fix the problem.
U-T-CL-M64
U-T-CL-M71
U-T-CL-V7560 were slightly better than the rest.
It was on U-CF-B80-60 when I started going through them all.
I have the service manual so could I go through page by page and set the values the same as the manual? Maybe there's another setting preventing the U-MOIP option from showing?
notengo13
Check this factory service menu log from UE40F8000 it has all settings from service menu and it's default values
Code:
[Factory] SamyGO E/F/H libFactory v0.1.7 - (c) zoelechat 2015
[Factory] _ZN13DBFactoryBase16m_pDBFactoryBaseE [0x26b52c8].
[Factory] _ZN13DBFactoryBase18SetSpecialItemDataEji10CDSourc e_k [0x654ab0].
[Factory] dlsym '_ZN13DBFactoryBase18GetSpecialItemDataEjPi10CDSou rce_k' failed.
[Factory] _ZN13DBFactoryBase18GetSpecialItemDataEjPi10CDSour ce_k14CDResolution_k [0x651f30].
[Factory] _ZN16SsExeFactoryBase19t_ConvertValueToStrEP17Fact oryItemNode_tPci [0x104ac20].
[Factory] _ZN14FactoryControl19t_ConvertValueToStrEP17Factor yItemNode_tPci [0x1066670].
[Factory] _ZN10TPCFactory8InstanceEv [0x687620].
[Factory] dlsym '_ZN16SsExeFactoryBase16GetVersionStringEN10TPCFac tory12EVersionTypeEPc' failed.
[Factory] _ZN16SsExeFactoryBase16GetVersionStringEN10TPCFact ory12EVersionTypeEPcj [0x104b31c].
[Factory] _ZSt18_Rb_tree_incrementPSt18_Rb_tree_node_base [0x631038].
[Factory] _ZN14FactoryControl17t_CheckItemEnableEP17FactoryI temNode_t [0x105ffe8].
[Factory] dlsym '_ZN8TCTvImpl27m_RecoverSettingsWithBootUpEv' failed.
[Factory] _ZN13DBFactoryBase27t_GetFactoryItemDefaultDataEP1 7FactoryItemNode_tPi10CDSource_k [0x654b24].
[Factory] lib_init, >>>
[Factory] * T-FXPDEUC-1128.1
[Factory] * T-FOXDEUS2-1002
[Factory] * BT Version : 2.1.14.252
[Factory] * E-Manual : FPDVBEUF-1.103
[Factory] * App Package :
[Factory] * Camera Version : 1.33.00
[Factory] * Mic Version : 2.89.00
[Factory] * Blaster-Version : 3.03
[Factory] * EDID SUCCESS
[Factory] * CALIB : AV / COMP / PC / HDMI /
[Factory] * Option : 40A2UF8E,EU_POLAND,8000,NONE
[Factory] * CPLD/LD : 0006 / NONE
[Factory] * Factory Zone: N
[Factory] * DTP-SDAL-FOXP-DEU-0026-3424
[Factory] * RFS:"Fox.P 0168" K/ 2015-08-26
[Factory] * KERNEL : 152.1132, / Onboot : 0081
[Factory] * DTP-DTVTD-3608-FOX-DVB-026
[Factory] * Backend IC[6], FW: 003D, Data: 0039
[Factory] * TCON Version: F40A2F707
[Factory] * Model : UE40F8000
[Factory] * Wired MAC SUCCESS
[Factory] * Wireless MAC SUCCESS
[Factory] * CIP SUCCESS
[Factory] * DRM:Crt O,Nf O,Wv O,Hc O,Dc /,Mx O,Ml /
[Factory] * Factory Data Ver : 200
[Factory] * EERC Version : 149
[Factory] * DTP-BP-HAL-3608-014-FoxP_DVB-015
[Factory] >>> Special items data <<<
[Factory] 8 Advanced -1 (def:0)
[Factory] 15 Checksum 0=0x0000 (def:0)
[Factory] 16 Factory Reset 0 (def:1)
[Factory] -> 0 <-> 1
[Factory] 17 Type 2=40A2UF8E (def:0)
[Factory] -> 0=NONE
[Factory] -> 1=40A2UF7E
[Factory] -> 2=40A2UF8E
[Factory] -> 3=46A2UF7E
[Factory] -> 4=46A2UF8E
[Factory] -> 5=55A2UF7E
[Factory] -> 6=55A2UF8E
[Factory] -> 7=60A2UF7E
[Factory] -> 8=60A2UF8E
[Factory] -> 9=75A2UF8L
[Factory] -> 10=85A2UU9S
[Factory] -> 11=60H2UF7E
[Factory] -> 12=65L2UF7E
[Factory] -> 13=65L2UF8E
[Factory] -> 14=51FPCrD
[Factory] -> 15=60FPCrD
[Factory] -> 16=64FPCrD
[Factory] -> 17=SEKPANEL
[Factory] -> 18=46A2UF8L
[Factory] -> 19=55A2UF8L
[Factory] -> 20=60A2UF8L
[Factory] -> 21=55A1UF0O
[Factory] -> 22=65L2UF8L
[Factory] -> 23=46A2UFBE
[Factory] -> 24=65A2UF8E
[Factory] -> 25=65A2UF8L
[Factory] -> 26=40A2UFBE
[Factory] -> 27=46R2UF7E
[Factory] -> 28=55R2UF7E
[Factory] -> 29=40A2UFEE
[Factory] -> 30=46A2UFEE
[Factory] -> 31=55A2UFEE
[Factory] -> 32=60A2UFEE
[Factory] -> 33=46A2UFFE
[Factory] -> 34=55A2UFFE
[Factory] -> 35=60A2UFFE
[Factory] -> 36=65A2UFFE
[Factory] -> 37=75A2UFCL
[Factory] -> 38=46A2UFFL
[Factory] -> 39=55A2UFFL
[Factory] -> 40=60A2UFFL
[Factory] -> 41=65A2UFFL
[Factory] 18 SW Model 3=UF8000 (def:0)
[Factory] -> 0=NONE
[Factory] -> 1=UF7000
[Factory] -> 2=UF7500
[Factory] -> 3=UF8000
[Factory] -> 4=UF8500
[Factory] -> 5=PF8500
[Factory] -> 6=US9
[Factory] -> 7=KS9C
[Factory] -> 8=SEK0000
[Factory] -> 9=UF7400
[Factory] -> 10=UF7450
[Factory] -> 11=UF8200
[Factory] 20 Watchdog 1=ON (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 22 RS-232 Jack 1=UART (def:1)
[Factory] -> 0=Debug
[Factory] -> 1=UART
[Factory] -> 2=Logic
[Factory] -> 3=FANET
[Factory] 24 Panel Display Time 45290=7548Hr (def:0)
[Factory] -> 0 <-> 1073741824
[Factory] 25 RF Mute Time 6=600ms (def:6)
[Factory] -> 0 <-> 12
[Factory] 26 Shop Mode 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 27 7.5 IRE NTSC 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 28 7.5 IRE OFFSET 0 (def:0)
[Factory] -> 0 <-> 255
[Factory] 30 HOT PLUG OFF HOLD TIME 12=1200ms (def:12)
[Factory] -> 0 <-> 20
[Factory] 31 HDMI FLT CNT SIG 0=0ms (def:0)
[Factory] 32 HDMI FLT CNT LOS 8=800ms (def:8)
[Factory] -> 0 <-> 40
[Factory] 34 UNSTABLE BAN CNT 25=1250ms (def:25)
[Factory] -> 0 <-> 200
[Factory] 35 HDMI Err Cnt 1 (def:1)
[Factory] 37 WD Count 0=12 (def:0)
[Factory] 39 IIC Bus Stop 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 40 Wall Mount 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 41 PnP Language 18=ENG (def:0)
[Factory] -> 1=KOR
[Factory] -> 2=ENG_US
[Factory] -> 3=SPA_US
[Factory] -> 4=FRA_US
[Factory] -> 5=POR_US
[Factory] -> 6=BUL
[Factory] -> 7=CRO
[Factory] -> 8=CZE
[Factory] -> 9=DAN
[Factory] -> 10=DUT
[Factory] -> 11=FIN
[Factory] -> 12=FRA
[Factory] -> 13=DEU
[Factory] -> 14=GRE
[Factory] -> 15=HUN
[Factory] -> 16=ITA
[Factory] -> 17=NOR
[Factory] -> 18=ENG
[Factory] -> 19=POL
[Factory] -> 20=POR
[Factory] -> 21=ROM
[Factory] -> 22=RUS
[Factory] -> 23=SER
[Factory] -> 24=SLK
[Factory] -> 25=SPA
[Factory] -> 26=SWE
[Factory] -> 27=TUR
[Factory] -> 28=CHI
[Factory] -> 29=HKG
[Factory] -> 30=TPE
[Factory] -> 31=JPN
[Factory] -> 32=MAO
[Factory] -> 33=CMN
[Factory] -> 34=YUE
[Factory] -> 35=HIN
[Factory] -> 36=EST
[Factory] -> 37=LAT
[Factory] -> 38=LTU
[Factory] -> 39=ARA
[Factory] -> 40=PER
[Factory] -> 41=QAA
[Factory] -> 42=AD
[Factory] -> 43=CAT
[Factory] -> 44=VAL
[Factory] -> 45=THA
[Factory] -> 46=HEB
[Factory] -> 47=IND
[Factory] -> 48=VIE
[Factory] -> 49=URD
[Factory] -> 50=AFR
[Factory] -> 51=ZUL
[Factory] -> 52=XHO
[Factory] -> 53=YOR
[Factory] -> 54=IGB
[Factory] -> 55=HAU
[Factory] -> 56=SWA
[Factory] -> 57=AMH
[Factory] -> 58=TAM
[Factory] -> 59=IRA
[Factory] -> 60=FIL
[Factory] -> 61=LIT
[Factory] -> 62=LAV
[Factory] -> 63=SLV
[Factory] -> 64=ALB
[Factory] -> 65=UKR
[Factory] -> 66=KAZ
[Factory] -> 67=MKD
[Factory] -> 68=MAY
[Factory] -> 69=WEL
[Factory] -> 70=GLA
[Factory] 42 TTX 1=ON (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 44 TTX Group 8=UserOSD (def:8)
[Factory] -> 0=WestEurope
[Factory] -> 1=EastEurope
[Factory] -> 2=Russian
[Factory] -> 3=Greek
[Factory] -> 4=Turkey
[Factory] -> 5=Arabic
[Factory] -> 6=Farsian
[Factory] -> 7=Arab/Hbrw
[Factory] -> 8=UserOSD
[Factory] 45 Visual Test 0=Disable (def:0)
[Factory] -> 0=Disable
[Factory] -> 1=Enable
[Factory] 46 TUNER [email protected]Ő@?’‰ (def:0)
[Factory] -> 0=Not DetectedŐ@?’‰
[Factory] -> 1=Si2173ATSCedŐ@?’‰
[Factory] -> 2=SEC_ISDB_TSdŐ@?’‰
[Factory] -> 3=ECHO_CVB_TSdŐ@?’‰
[Factory] -> 4=SEMCO_TCS2SdŐ@?’‰
[Factory] -> 5=TDA18273_ECHOCTI?’‰
[Factory] -> 6=ECHOC_T2CECHOCTI?’‰
[Factory] -> 7=ECHOC_T2CS2HOCTI?’‰
[Factory] -> 8=ECHOC_TCCS2HOCTI?’‰
[Factory] -> 9=ALPS_TCS2S2HOCTI?’‰
[Factory] -> 10=Echo_CD_CN2HOCTI?’‰
[Factory] -> 11=ECHOC_T2CS2_DUAL?’‰
[Factory] -> 12=T2CS2_DUAL2_DUAL?’‰
[Factory] -> 13=TCS2_DUALL2_DUAL?’‰
[Factory] -> 14=T2CS2_DUAL_SDUAL?’‰
[Factory] -> 15=TCS2_DUAL_SSDUAL?’‰
[Factory] -> 16=SI2190UAL_SSDUAL?’‰
[Factory] -> 17=SI21XX_T2CSSDUAL?’‰
[Factory] -> 18=SI2190_DUALSDUAL?’‰
[Factory] -> 19=SI21XX_T2C_DUALL?’‰
[Factory] -> 20=SI2190_DTMBDUALL?’‰
[Factory] -> 21=ECHOCV_DUALDUALL?’‰
[Factory] -> 22=SI21XX_CXD2842LL?’‰
[Factory] 48 N/D ADJ 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] -> 2=FIX
[Factory] 50 EER Reset 0 (def:0)
[Factory] 66 1st_Y_GH 0 (def:252)
[Factory] -> 0 <-> 511
[Factory] 67 1st_Y_GL 0 (def:245)
[Factory] 68 1st_Cb_BH 0 (def:0)
[Factory] 69 1st_Cb_BL 0 (def:0)
[Factory] 70 1st_Cr_RH 0 (def:0)
[Factory] 71 1st_Cr_RL 0 (def:0)
[Factory] 72 2nd_R_L 130 (def:130)
[Factory] 73 2nd_G_L 130 (def:130)
[Factory] 74 2nd_B_L 130 (def:130)
[Factory] 75 2nd_R_H 69 (def:107)
[Factory] 76 2nd_G_H 69 (def:107)
[Factory] 77 2nd_B_H 69 (def:107)
[Factory] 78 Sub Brightness 126 (def:126)
[Factory] 79 R-Offset 128 (def:128)
[Factory] 80 G-Offset 128 (def:128)
[Factory] 81 B-Offset 128 (def:128)
[Factory] 82 Sub Contrast 134 (def:134)
[Factory] 83 R-Gain 128 (def:128)
[Factory] 84 G-Gain 128 (def:128)
[Factory] 85 B-Gain 128 (def:128)
[Factory] 90 W/B MOVIE ON/OFF 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 91 MODE 0=Dynamic (def:0)
[Factory] -> 0=Dynamic
[Factory] -> 1=Movie
[Factory] -> 2=Standard
[Factory] -> 3=Natural
[Factory] 92 Color Tone 3=COOL (def:3)
[Factory] -> 3=COOL
[Factory] -> 4=NORMAL
[Factory] -> 5=WARM1
[Factory] -> 6=WARM2
[Factory] 93 MSub Brightness 126 (def:126)
[Factory] 94 MSub Contrast 118 (def:118)
[Factory] 95 W2_Rgain 31 (def:31)
[Factory] -> -128 <-> 127
[Factory] 96 W2_Bgain -64 (def:-64)
[Factory] 97 W2_Roffset 0 (def:0)
[Factory] 98 W2_Boffset 0 (def:0)
[Factory] 99 Movie Gamma 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=0.852
[Factory] -> 2=0.882
[Factory] -> 3=0.902
[Factory] -> 4=0.932
[Factory] -> 5=0.952
[Factory] -> 6=0.982
[Factory] -> 7=M1
[Factory] -> 8=M2
[Factory] -> 9=M3
[Factory] -> 10=M4
[Factory] 100 Movie Contrast 95 (def:95)
[Factory] -> 0 <-> 100
[Factory] 101 Movie Bright 45 (def:45)
[Factory] 102 Movie Color 50 (def:50)
[Factory] 103 Movie Sharpness 20 (def:20)
[Factory] 104 Movie Tint 50=0 (def:0)
[Factory] -> -50 <-> 50
[Factory] 105 Movie Backlight 14 (def:14)
[Factory] 106 Standard Contrast 100 (def:100)
[Factory] 107 Standard Brightness 45 (def:45)
[Factory] 108 Standard Color 50 (def:50)
[Factory] 109 Standard Sharpness 50 (def:50)
[Factory] 110 Standard Tint 50=0 (def:0)
[Factory] 111 Standard Backlight 12 (def:12)
[Factory] 112 Hospitality Mode 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] -> 2=Standalone
[Factory] 113 Power On Channel 1 (def:1)
[Factory] -> 0 <-> 9999999
[Factory] 114 Power On Volume 10 (def:10)
[Factory] 115 Power On Source 0=TV (def:0)
[Factory] -> 0=TV
[Factory] -> 1=HDMI1
[Factory] -> 2=HDMI2/DVI
[Factory] -> 3=HDMI3
[Factory] -> 4=HDMI4
[Factory] -> 5=Ext.
[Factory] -> 6=AV4
[Factory] -> 7=COMP
[Factory] -> 8=TV
[Factory] -> 9=TV
[Factory] -> 10=TV
[Factory] 116 Panel Button Lock 0=Unlock (def:0)
[Factory] -> 0=Unlock
[Factory] -> 1=Lock
[Factory] -> 2=OnlyPower
[Factory] -> 3=Menu/Source
[Factory] 117 Min Volume 0 (def:0)
[Factory] 118 Max Volume 100 (def:100)
[Factory] 119 Picture Menu Lock 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 120 Sub Amp Volume 6 (def:6)
[Factory] -> 0 <-> 32
[Factory] 121 Sub Amp Mode 2 (def:2)
[Factory] 122 Local Time 1=Manual (def:1)
[Factory] -> 0=Auto
[Factory] -> 1=Manual
[Factory] -> 2=TTX
[Factory] 125 EDID WRITE PC 1=Success (def:0)
[Factory] 130 HDMI EDID Ver 0=HDMI 1.2 (def:0)
[Factory] -> 0=HDMI 1.2
[Factory] -> 1=HDMI 1.3
[Factory] 132 DVI/HDMI SOUND 0=Auto (def:0)
[Factory] -> 0=Auto
[Factory] -> 1=DVI
[Factory] 136 Num of ATV 1 (def:1)
[Factory] 137 Num of DTV 2 (def:2)
[Factory] 138 Num of AV 1 (def:1)
[Factory] 139 Num of SVIDEO 0 (def:0)
[Factory] 140 Num of COMP 1 (def:1)
[Factory] 141 Num of HDMI 4 (def:4)
[Factory] 142 Num of PC 0 (def:0)
[Factory] 143 Num of SCART 1 (def:1)
[Factory] 144 Num of DVI 0 (def:0)
[Factory] 145 Num of OPTICAL Link 1 (def:1)
[Factory] 146 Num of MEDIA 1 (def:1)
[Factory] 147 Num of PANEL KEY 7 (def:7)
[Factory] -> 0 <-> 8
[Factory] 148 Num of USB Port 3 (def:3)
[Factory] 149 LNA Support 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 151 Select LCD/PDP 0=LCD (def:0)
[Factory] -> 0=LCD
[Factory] -> 1=PDP
[Factory] 153 Light Effect 1=ON (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 154 PIXEL SHIFT TEST 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 155 Lvds Format 1=JEIDA (def:1)
[Factory] -> 0=PDP
[Factory] -> 1=JEIDA
[Factory] -> 2=VESA
[Factory] 156 Source 0=Current (def:0)
[Factory] -> 0=Current
[Factory] -> 1=All
[Factory] 157 HDMI/DVI SEL 2 (def:2)
[Factory] -> 1 <-> 4
[Factory] 158 LVDS SSC ON/Off 1=ON (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 164 Contrast Dimming 1=ON (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 165 Region 4=PANEURO (def:0)
[Factory] -> 1=KOR
[Factory] -> 2=USA
[Factory] -> 3=BRA
[Factory] -> 4=PANEURO
[Factory] -> 5=CHI
[Factory] -> 6=HKG
[Factory] -> 7=PANNORDIG
[Factory] -> 8=ASIA_ATV
[Factory] -> 9=ASIA_DTV
[Factory] -> 10=TAIWAN
[Factory] -> 11=AFR
[Factory] -> 12=PHI
[Factory] -> 13=COLOMBIA
[Factory] 166 Info Link Server Type 0=operating (def:0)
[Factory] -> 0=operating
[Factory] -> 1=development
[Factory] -> 2=developing
[Factory] 167 N_Rgain 20 (def:20)
[Factory] 168 N_Bgain -21 (def:-21)
[Factory] 169 N_Roffset 0 (def:0)
[Factory] 170 N_Boffset 0 (def:0)
[Factory] 179 MediaPlay DLNA 1=ON (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 180 Language_Arabic 20=EU (def:0)
[Factory] -> 0=UNKNOWN
[Factory] -> 1=EAST ASIA
[Factory] -> 2=IRAN
[Factory] -> 3=ISRAEL
[Factory] -> 4=MIDDLE ASIA
[Factory] -> 5=S_AMERICA
[Factory] -> 6=TAIWAN
[Factory] -> 7=AFRICA
[Factory] -> 8=N_AFRICA
[Factory] -> 9=WEST ASIA
[Factory] -> 10=MALAYSIA
[Factory] -> 11=KR
[Factory] -> 12=US
[Factory] -> 13=CIS
[Factory] -> 14=TURKEY
[Factory] -> 15=CHINA
[Factory] -> 16=HONGKONG
[Factory] -> 17=JAPAN
[Factory] -> 18=CANADA
[Factory] -> 19=PHILIPINE
[Factory] -> 20=EU
[Factory] -> 21=AUSTRAILIA
[Factory] 183 Subwoofer Support 2 (def:2)
[Factory] -> 0 <-> 7
[Factory] 185 HDMI EDID Port 0=NONE (def:0)
[Factory] -> 0=NONE
[Factory] -> 2=Not Support
[Factory] 187 China HD 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 188 NT Conversion 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 190 High Devi 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 192 Unbalance 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 194 Local Set 22=EU_POLAND (def:0)
[Factory] 199 Exhibition Mode 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 204 TOOLS Support 1659 (def:1659)
[Factory] -> 0 <-> 268435455
[Factory] 205 OTN Support 1=ON (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 206 Carrier_Mute 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 208 Num Of Display 2 (def:2)
[Factory] -> 1 <-> 2
[Factory] 210 MediaPlay DB 2=On with 10MB (def:2)
[Factory] -> 0=OFF
[Factory] -> 1=On with 5MB
[Factory] -> 2=On with 10MB
[Factory] 211 24Px4 Support 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 212 HDMI Callback 1=ON (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 214 OTN Test Server 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=A Zone
[Factory] -> 2=B Zone
[Factory] -> 3=C Zone
[Factory] -> 4=D Zone
[Factory] -> 5=E Zone
[Factory] 215 BD Wise Support 1=ON (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 216 Ch Table 0=NONE (def:0)
[Factory] -> 0=NONE
[Factory] -> 1=PBA
[Factory] -> 2=SUWON
[Factory] -> 3=SESK
[Factory] -> 4=SEH
[Factory] -> 5=SERK
[Factory] -> 6=SEIN
[Factory] -> 7=SAVINA
[Factory] 217 RF Remocon Support 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 219 OTN Server Type 0=operating (def:0)
[Factory] 222 HDMI Black Level 0=Normal (def:0)
[Factory] -> 0=Normal
[Factory] -> 1=Low
[Factory] 228 Data Service Support 0=OFF (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 244 Info Link Country 0=None (def:0)
[Factory] -> 0=None
[Factory] -> 1=Korea
[Factory] -> 2=USA
[Factory] -> 3=Canada
[Factory] -> 4=Mexico
[Factory] -> 5=Argentina
[Factory] -> 6=Chile
[Factory] 248 SI Vendor 0=Samsung (def:0)
[Factory] 249 Music Mode AV 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 250 Music Mode PC 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 251 Music Mode Comp 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 252 Music Mode Backlight 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 258 Time Format 1=24 Hour (def:1)
[Factory] -> 0=12 Hour
[Factory] -> 1=24 Hour
[Factory] 263 Menu Display 1=ON (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 264 Hospitality Logo 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=BMP
[Factory] -> 2=AVI
[Factory] -> 3=BOTH
[Factory] 265 Hospitality Logo DL 0 (def:0)
[Factory] 266 Logo Display Time 1=5 Second (def:1)
[Factory] -> 0=3 Second
[Factory] -> 1=5 Second
[Factory] -> 2=7 Second
[Factory] 267 Power On Option 0=Last Option (def:0)
[Factory] -> 0=Last Option
[Factory] -> 1=Power ON
[Factory] -> 2=Standby
[Factory] 268 Auto Source 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] -> 2=PC
[Factory] 269 Energy Saving 0=Off (def:0)
[Factory] -> 0=Off
[Factory] -> 1=Low
[Factory] -> 2=Medium
[Factory] -> 3=High
[Factory] 272 Pan Euro MHEG 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 273 Setting Auto Initialize 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 274 Welcome Message 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 275 Edit Welcome Message 0 (def:0)
[Factory] 276 Energy Saving Timer 0 (def:0)
[Factory] 277 TV Version 0=1.0 (def:0)
[Factory] -> 0=1.0
[Factory] -> 1=2.0
[Factory] 278 Caption 0 (def:0)
[Factory] 279 Channel Editor 0 (def:0)
[Factory] 281 Num Of Tuner 2 (def:2)
[Factory] 282 Num of DECODER 1 (def:1)
[Factory] 288 Type Of PANEL KEY 0=Horizontal (def:0)
[Factory] -> 0=Horizontal
[Factory] -> 1=Vertical
[Factory] -> 2=PDPVertical
[Factory] -> 3=PDPHorizon
[Factory] -> 4=None
[Factory] 290 Num of IPTV 1 (def:1)
[Factory] 293 Cable Modulation 2=Error (def:2)
[Factory] -> 0=QAM
[Factory] -> 1=8VSB
[Factory] 295 Channel Type 0=ATV (def:0)
[Factory] -> 0=ATV
[Factory] -> 1=DTV
[Factory] -> 2=CATV
[Factory] -> 3=CDTV
[Factory] -> 4=SDTV
[Factory] -> 5=FREESAT
[Factory] -> 6=TIVUSAT
[Factory] -> 7=CANALSAT
[Factory] 301 PVR Support 1=ON (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 302 Dynamic SI 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 304 3D_Standard_Contrast 100 (def:100)
[Factory] 305 3D_Standard_Brightness 45 (def:45)
[Factory] 307 Mixed Channel Map 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 308 Front Color 17=U-CF-B80 (def:17)
[Factory] -> 0=NONE
[Factory] -> 1=P-W-D-40
[Factory] -> 2=P-W-D-49
[Factory] -> 3=P-W-D-55
[Factory] -> 4=P-W-D-85
[Factory] -> 5=U-S-C-5K
[Factory] -> 6=U-T-CL-M61
[Factory] -> 7=U-T-WG-M63
[Factory] -> 8=U-T-CG-M64
[Factory] -> 9=U-T-CL-M64
[Factory] -> 10=U-T-WG-M64
[Factory] -> 11=U-T-CL-M65
[Factory] -> 12=U-T-CL-M67
[Factory] -> 13=U-T-CL-M68
[Factory] -> 14=U-T-CL-M71
[Factory] -> 15=U-T-CL-V75
[Factory] -> 16=U-T-CL-B75
[Factory] -> 17=U-CF-B80
[Factory] -> 18=N/A
[Factory] -> 19=U-CF-B80-75
[Factory] -> 20=U-CF-B85
[Factory] -> 21=UHD-85
[Factory] -> 22=U-T-CL-M61-65
[Factory] -> 23=U-TC-V71
[Factory] -> 24=U-TC-V7160
[Factory] -> 25=U-T-CL-V7560
[Factory] -> 26=U-CF-B80-60
[Factory] -> 27=U-CF-B80-65
[Factory] -> 28=U-CF-B82-75
[Factory] 310 HDMI 3D DET 1 (def:1)
[Factory] -> 1 <-> 10
[Factory] 312 Mono Last Memory 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 322 Power On Volume EN 0=User Defined (def:0)
[Factory] -> 0=User Defined
[Factory] -> 1=Last Saved
[Factory] 323 Power On Channel EN 0=User Defined (def:0)
[Factory] 325 Num of PVR RECORD 1 (def:1)
[Factory] 330 3D_WBMOVIE ON/OFF 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 331 3D_MODE 0=Dynamic (def:0)
[Factory] 332 3D_Color Tone 3=COOL (def:3)
[Factory] -> 3=COOL
[Factory] 333 3D_Sub_Contrast 138 (def:138)
[Factory] 334 3D_Sub_Brightness 126 (def:126)
[Factory] 335 3D_MSub Brightness 126 (def:126)
[Factory] 336 3D_MSub Contrast 138 (def:138)
[Factory] 337 3D_C_Rgain 21 (def:21)
[Factory] 338 3D_C_Bgain -3 (def:-3)
[Factory] 339 3D_C_Roffset 0 (def:0)
[Factory] 340 3D_C_Boffset 0 (def:0)
[Factory] 341 3D_N_Rgain 35 (def:35)
[Factory] 342 3D_N_Bgain -30 (def:-30)
[Factory] 343 3D_N_Roffset 0 (def:0)
[Factory] 344 3D_N_Boffset 0 (def:0)
[Factory] 345 3D_W2_Rgain 56 (def:56)
[Factory] 346 3D_W2_Bgain -73 (def:-73)
[Factory] 347 3D_W2_Roffset 0 (def:0)
[Factory] 348 3D_W2_Boffset 0 (def:0)
[Factory] 349 3D_Movie Contrast 100 (def:100)
[Factory] 350 3D_Movie Bright 45 (def:45)
[Factory] 351 3D_Movie Color 50 (def:50)
[Factory] 352 3D_Movie Sharpness 20 (def:20)
[Factory] 353 3D_Movie Tint 50=0 (def:0)
[Factory] 354 3D_Movie Backlight 20 (def:20)
[Factory] 355 3D_Movie Gamma 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 7=M1
[Factory] -> 8=M2
[Factory] -> 9=M3
[Factory] -> 10=M4
[Factory] 356 3D_M_Sub_Gamma 0 (def:0)
[Factory] -> -3 <-> 3
[Factory] 357 3D_HDMI Black Level 0=Normal (def:0)
[Factory] -> 1=Low
[Factory] 359 3D_Standard_Sharpness 50 (def:50)
[Factory] 360 3D_Standard_Color 50 (def:50)
[Factory] 361 3D_Standard_Tint 50=0 (def:0)
[Factory] 362 3D_Standard_Backlght 20 (def:20)
[Factory] 366 Num of RVU 0 (def:0)
[Factory] 373 Widget Mode 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 388 SIRCH Channel 87 (def:87)
[Factory] 392 Speaker EQ 1=ON (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 396 Channel Rescan Message 1=ON (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 398 OTA Support 1=General (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=General
[Factory] 399 SIRCH Update Time 1=1hour (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=1hour
[Factory] -> 2=2hour
[Factory] -> 3=12:00 am
[Factory] -> 4=2:00 am
[Factory] -> 5=12:00 pm
[Factory] -> 6=2:00 pm
[Factory] 403 HDMI Music Mode 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 406 WIFI REGION 4=E (def:0)
[Factory] -> 0=A
[Factory] -> 1=B
[Factory] -> 2=C
[Factory] -> 3=D
[Factory] -> 4=E
[Factory] -> 5=F
[Factory] -> 6=G
[Factory] -> 7=H
[Factory] -> 8=I
[Factory] -> 9=J
[Factory] -> 10=K
[Factory] -> 11=L
[Factory] -> 12=M
[Factory] -> 13=N
[Factory] -> 14=O
[Factory] -> 15=P
[Factory] -> 16=Q
[Factory] -> 17=R
[Factory] -> 18=S
[Factory] -> 19=T
[Factory] -> 20=U
[Factory] -> 21=V
[Factory] -> 22=W
[Factory] -> 23=X
[Factory] -> 24=Y
[Factory] -> 25=Z
[Factory] -> 26=AA
[Factory] -> 27=AB
[Factory] 412 SVC Reset 0 (def:0)
[Factory] 416 e-Pop Default 1=ON (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 419 Sound Bar Out 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 421 BT_AUDIO_ON_OFF 1=ON (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 423 Auto Power 0=LAST POWER (def:0)
[Factory] -> 0=LAST POWER
[Factory] -> 1=ALWAYS ON
[Factory] -> 2=ALWAYS OFF
[Factory] 430 Num of IPTV CIP 0 (def:0)
[Factory] 432 AR Count 95 (def:0)
[Factory] 434 BOM Model 8000 (def:0)
[Factory] 435 Num of CI 1 (def:1)
[Factory] 445 M_N_Rgain 14 (def:14)
[Factory] 446 M_N_Bgain -19 (def:-19)
[Factory] 447 M_N_Roffset 0 (def:0)
[Factory] 448 M_N_Boffset 0 (def:0)
[Factory] 449 M_W2_Rgain 32 (def:32)
[Factory] 450 M_W2_Bgain -58 (def:-58)
[Factory] 451 M_W2_Roffset 0 (def:0)
[Factory] 452 M_W2_Boffset 0 (def:0)
[Factory] 456 MultiAcc 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 482 CI +1.3 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 484 Num of RUI 0 (def:0)
[Factory] 485 SWU Fail Test 0 (def:0)
[Factory] 486 SWU Duration 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 487 SWU Reset 0 (def:0)
[Factory] 488 SWU_Diag_Code 0 (def:0)
[Factory] 497 CAL Data Backup 0 (def:0)
[Factory] 498 CAL Data Restore 0 (def:0)
[Factory] 501 Num of Network Stream 1 (def:1)
[Factory] 506 Fast Boot in Production 0=OFF (def:1)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 510 CDD mode 0=Broadcast (def:0)
[Factory] -> 0=Broadcast
[Factory] -> 1=Test
[Factory] 517 Server Type 0=Operating (def:0)
[Factory] -> 0=Operating
[Factory] -> 1=Development
[Factory] 518 RTS mode 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 525 Num of ISP 1 (def:1)
[Factory] 530 USB Serial 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 531 WB_N_R_Offset 128 (def:128)
[Factory] 532 WB_N_B_Offset 128 (def:128)
[Factory] 533 WB_N_R_Gain 128=148 (def:128)
[Factory] 534 WB_N_B_Gain 128=107 (def:128)
[Factory] 535 R1_Gain 530 (def:512)
[Factory] -> 256 <-> 766
[Factory] 536 R2_Gain 526 (def:512)
[Factory] 537 R3_Gain 522 (def:512)
[Factory] 538 R4_Gain 520 (def:512)
[Factory] 539 R5_Gain 518 (def:512)
[Factory] 540 R6_Gain 516 (def:512)
[Factory] 541 R7_Gain 516 (def:512)
[Factory] 542 R8_Gain 514 (def:512)
[Factory] 543 R9_Gain 512 (def:512)
[Factory] 544 R10_Gain 512 (def:512)
[Factory] 545 G1_Gain 526 (def:512)
[Factory] 546 G2_Gain 522 (def:512)
[Factory] 547 G3_Gain 518 (def:512)
[Factory] 548 G4_Gain 516 (def:512)
[Factory] 549 G5_Gain 516 (def:512)
[Factory] 550 G6_Gain 514 (def:512)
[Factory] 551 G7_Gain 514 (def:512)
[Factory] 552 G8_Gain 512 (def:512)
[Factory] 553 G9_Gain 512 (def:512)
[Factory] 554 G10_Gain 512 (def:512)
[Factory] 555 B1_Gain 522 (def:512)
[Factory] 556 B2_Gain 518 (def:512)
[Factory] 557 B3_Gain 516 (def:512)
[Factory] 558 B4_Gain 514 (def:512)
[Factory] 559 B5_Gain 512 (def:512)
[Factory] 560 B6_Gain 510 (def:512)
[Factory] 561 B7_Gain 508 (def:512)
[Factory] 562 B8_Gain 510 (def:512)
[Factory] 563 B9_Gain 510 (def:512)
[Factory] 564 B10_Gain 512 (def:512)
[Factory] 565 USING_PSI_UPDATE 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 566 Voice Debug 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 597 EOS Click 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 599 EEPG Enable 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 600 CES Mode 0=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 650 Source Direct On/Off -1=OFF (def:0)
[Factory] -> 0=OFF
[Factory] -> 1=ON
[Factory] 696 EU_CIS -1 (def:0)
[Factory] <<< lib_deinit
sweetaz
@ notengo 13.
Thank you again for sending through these factory setting. I finally fixed my TV by matching the settings you sent. You sir are a legend!!
notengo13
@ notengo 13.
You're welcome. I'm just one of the brother-in-law. Trying to help.
Where was a problem or what you changed?
sweetaz
I went into the ADC/WB settings and matched all the color settings to match the ones you sent me and it worked perfectly. The ones that were in my TV were all over the place which is probably why the color was so bad. I checked the front color and tuner settings to make sure they were the same too so working great now. Thanks again! I've been trying to resolve this problem for a year!.. lol
If you search Samsung UE55 F8000 pink screen on here you'll see how bad the picture was.
