how to reset blaupunkt woodstock dab 54 after battery change
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by mazz1957, Jan 10, 2012.
  1. mazz1957
    mazz1957
    Jan 10, 2012
    2
    hiya all. ive just bought a range rover fitted with a blaupunkt woodstock dab 54. it was working brill till i changed the battery last week now i cant find out how to reset it. the display just reads "k card not ok" when the car is started or when we touch the on switch of the radio. i have heard so many good things about these radios and in the time i had it working it was brilliant. i would appreciate any help.
    thanks in anticipation
    neil:lease:
  2. koush
    koush
    May 6, 2009
    218
    28
    +25
  3. mazz1957
    mazz1957
    Jan 10, 2012
    2
    awww thanks a lot for your input koush, ill have a look at that. :smashin:
  4. topgazza
    topgazza
    Sep 3, 2006
    14,373
    Near Basingstoke
    +3,556
    I have a DAB54 and there should be a SD card sized code key. You put it in the SD slot and turn the ignition on and when the radio powers up you can take the SD card out and keep it somewhere safe. I'm assuming you didn't get it with the car. Is it somewhere in all the paperwork ?
    Great HU IMO opinion. DAB market is shockingly under provided
  5. WOODERR
    WOODERR
    Mar 30, 2018
    4
    AUSTRALIA
    l too have a Blaupunkt Woodstock DAb54 my problem taking the out radio after a flat battery l saw the installers have taken the serial nos. sticker off the unit to screw it to the cradle , this was done 12 years ago the sticker is missing what else can l do ?
