how to reset a denon 2805
Discussion in 'AV Receivers & Amplifiers' started by shimmie1725, Jul 19, 2004.
Tags:
  1. shimmie1725
    shimmie1725
    Does anyone know hou to reset a denon 2805
    Mine is all jazzed up
  2. Arcangel
    Arcangel
    It will tell you in the manual - check Re-Intialization of the Processor. Usually involves turning the Power on whilst simultaneously holding down two buttons on the front panel. This button combination varies from model to model though. :)
  3. ash71
    ash71
    May 24, 2004
    70
    Page 85 of the instruction book will show you how
