How to remove the Elys2 cartridge from the Rega Planar 3
wate49
Anyone knows how to remove the Elys2 cartridge that comes pre-installed with the Rega Planar 3? I wanted to replace the Elys2 with the Nakaoga MP-110. It seems the 3 bolts attached are not a typical type I can remove with my Philips screwdriver. Any particular tools needed?
Thank you,
Watee
oscroft
Judging by photos I can find on the Rega site and other places (and not personal experience), it looks like the main two need a nut driver (or fine nose pliers) and an Allen key/hex key/hex bit, and the third one (at the front) needs just an Allen key/hex key/hex bit?
wate49
BT Bob
I think the 2 bolts that come from the bottom-up use the same allen key as the front one.
This is the RP6, but shows the process.
RugbyAl
The front screw is the same as the other 2 just reversed. Just an Allen key and small spanner/pliers required so very simple really, I have no idea why a Phillips screwdriver is on your mind.
Please be aware you will need to align the cartridge to a gauge for correct alignment, Baerwald, Stevenson etc. If you don't do this expect high distortion and poor sound quality.
If you're struggling with simply removing the cartridge then I suggest you have a read up on cartridge alignment before you go any further...
wate49
Thanks all for the suggestions. I could easily replace the cartridge on my previous AT LP3. Just got the P3 and the tone arm and the attached Elys2 are different that’s why I wanted to ask and make sure before I did any harm to it.
BT Bob
The Rega 3-point fitting makes alignment a bit easier, but you're right - it'll still probably need a small tweak to get the best out of it. Plus tracking weight & anti-skate.
RugbyAl
But the MP110 the OP wants to fit doesn't have 3 point fixing. Agree on tracking weight and anti-skate though.
andybebbs
It just fixes on with the two supied bolts but you will need to align it with a protractor as well as set the weight and tracking.
BT Bob
Bugger!!! You're right - my bad...... I totally forgot - too wrapped up in finding a video on the Rega carts..... :facepalm: :D
