How to remove black bar on right of Panny pic?
Discussion in 'Plasma TVs Forum' started by giantteabag, Nov 3, 2004.
  1. giantteabag
    giantteabag
    I send my Sky+ RGB feed thru a JS VGA Converter & then into the pw7 PC input.
    When I watch BBC News (1 & News 24) & they cut to a video piece, I get a black bar down the right hand side of the picture, but not on the left. Even going to zoom setting doesnt remove it.
    When prog returns to the studio presenter, the pic fills the whole screen.
    What's going on & how do I stop it?
    Thanks.
  2. TeresaTT
    TeresaTT
    Sep 11, 2004
    508
    Walsall
    +13
    This is normal and happened on my Loewe Xelos CRT and I now get it on my PWD6. It seems to happen when they broadcast a 4:3 image as 16:9. It's in the original broadcast source and I don't think there's anything that we can do about it.
  3. giantteabag
    giantteabag
    Thanks for the prompt feedback.
    At least I don't have to worry about diving into the setup menu!
    Cheers.
  4. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    Teresa is correct. News 24 zooms 4:3 material to 14:9 and initially left narrow black bars on each side of the picture. Now they've opted to fill the screen on the left hand side and have a wider black bar on the right. When they have a horizontal red bar with story details on it, that extends to fill both sides of the screen even when they're showing zoomed 4:3 material.
  5. Uzey
    Uzey
    If you look at THEIR plasma's in the studio, they do it too! This is how I found out that I shouldn't worry about it!
