How to remove a Pioneer head unit from my car
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by montevideano, Aug 5, 2006.
  1. montevideano
    montevideano
    Hi folks,
    I have an 1993 Hyundai Sonata that I'm planning to donate to a charity group. It has a Pioneer DEH-P6500 car radio/cd player. I would like to remove it and install it in my little toyota pick-up.
    My problem is that I dont know how to remove the head unit. Do I need special tools?
    I welcome any ideas.
    thanks,
    Montevideano:lease:
  2. RBZ5416
    RBZ5416
    Nov 4, 2002
    19,179
    +7,319
    Yes, you will need a set of these. They go in either side of the head unit (you may need to remove the bezel) & unlock the HU from the cage. The cage itself will just be held by tabs that have been bent inwards.
    Figure 7 here.
    Edit
    Link seems a bit temperamental. If it doesn't work the installation PDF that I'm trying to link to can be found by searching the manual database for 6500 from here.
  3. montevideano
    montevideano
    Crocodile,
    Thank you very much for your response. I'll see if I can get a set of these tools.
    Thanks,
    Montevideano
