How to reduce the picture size on a HP laptop
Discussion in 'Desktop & Laptop Computers Forum' started by laserbeam, Jun 12, 2019.
  1. laserbeam
    laserbeam
    Aug 2, 2013
    1,119
    48
    Brighton
    +27
    My wife is trying to sort out all the photos on her laptop but whenever she clicks on one it is 100% in size and she wants it set at 50%.She is having to change the sizes one by one can she set the size at 50% so it stays at 50%.The model number looks like L2W43A and perhaps ABU at the end.Thanks
  2. techquest
    techquest
    Jun 4, 2019
    110
    earth
    +21
    It's nothing to do with the laptop it's down to what she is using to view them with. What program is she using?
  3. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,900
    Norfolk
    +2,536
    100% and 50% as sizes would typically be the zoom level the program you're using to view them is currently set at, and not a characteristic of the photograph.
    As techquest says, you need to look in the options of whatever that program is. That'll be the only place you can change the default size it shows images at.
  4. laserbeam
    laserbeam
    Aug 2, 2013
    1,119
    48
    Brighton
    +27
    I have sorted this problem out now I called into my local PC shop which have done before and he sorted it out in no time.He said my wife should have Paint what ever that means but thanks for the replies much appreciated.
  5. techquest
    techquest
    Jun 4, 2019
    110
    earth
    +21
    Yes as suspected it was the software she was using.
    Paint is supplied as a freebie by Microsoft in windows. Just type paint in the search bar and you should see the Paint app come up. Click on that and it will bring up paint. She can then view any of here photos with it. Down in the bottom right corner of the Paint window you will see a slider that you just slide left to make the picture smaller. Easy to use and she will soon get used to it.
    Let us know if we can help further.
