How to record sky tv with Toshiba RD-88DT
Discussion in 'Blu-ray & DVD Players & Recorders' started by shareiq, Jun 15, 2009.
  1. shareiq
    shareiq
    May 30, 2009
    5
    I have recently bought Toshiba RD-88DT, how do i use it to record sky tv. Do i need to have an rgb scart to s video lead to achieve this?
    Any response would be appreciated.
    :lease:
  2. ramjet
    ramjet
    May 21, 2006
    3,761
    +622
    the standard connection from a sky box to any recorder is a fully wired 21 pin scart from the tv out scart socket of the sky box to the line input scart socket of the recorder
    then set the sky box and recorder to 16:9 widescreen and also RGB
  3. shareiq
    shareiq
    May 30, 2009
    5
    Thanks for the response, but Toshiba RD-88DT doesn't have a rgb scart input. It only has svideo or composite .
  4. DrPepper
    DrPepper
    Oct 2, 2001
    3,404
    Barking Essex
    +276
  5. BigCam
    BigCam
    Apr 25, 2009
    519
    +82
    Hi :hiya:
    Those connections on Front of machine are usually for hooking up a Video Camera to Recorder
    If you look at the back of machine there is 2 Scart sockets
    One for TV out(AV1)
    Other for AV/decoder in (AV2)
    Connect Sky to AV2 to record it
    Select AV2 or Line 2 input on Recorder remote
    Set TV to DVD input to confirm right Input on DVD has been selected for Recording Sky
    BigCam
  6. shareiq
    shareiq
    May 30, 2009
    5
    Many thanks, i will follow this and update the forum. cheers!:thumbsup:
  7. bass
    bass
    Oct 20, 2009
    hi shareiq,
    did this work ok? were you able to record via the scart lead?
    also are you able to do timed recordings?
    many thanks
