How to record from CD with Sonic Stage
Discussion in 'Headphones, Earphones & Portable Music' started by cwmbrancon, Apr 6, 2005.
  1. cwmbrancon
    cwmbrancon
    I have been importing my WMA files from Media Player to Sonic Stage and onto the NW - HD3.
    I inserted a new CD into my PC and the autoplay gave me the option to record using Sonic Stage. I unchecked the 'automatically record using Sonic Stage' box and the CD recorded fine.
    I have inserted another Cd and the pop up 'autoplay' box that gives the options does not appear.
    How can i manually tell 'Sonic Stage' to record from the CD. I can't see a record button or a Rip button anywhere on the screen.
  2. scottydog
    scottydog
    Mar 22, 2005
    55
    You need to go to 'Music Source'. There should be a Music Source button at the top of your SonicStage screen which will give you the options available. It is also available from 'View' in the menu bar at the top of the screen. The record buttons are available once in Music Source with the 'record from CD' option.
    The first time I tried to record from CD I also had the auto record setting on. I didn't like it and switched it off. The next time I wanted to record a CD I couldn't get the 'Music Source' button to work. It just wanted to connect me to the internet. Choosing the music source from 'View' and selecting 'record from CD' worked and has done ever since.
  3. cwmbrancon
    cwmbrancon
    Cheers Scottydog
