how to record freeview on VCR?
Discussion in 'Freeview & YouView' started by martingilbraith, Jan 18, 2005.
  1. martingilbraith
    martingilbraith
    I have connected my new freeview box with TV and VCR as intended (I think) but when I try to record digital TV on the AV channel of the VCR I get nothing but a blank screen. Any suggestions?
    I notice that neither of my SCART cables has all 20 pins at either end of them, could this have anything to do with it?
    thanks,
    Martin
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Buy lump hammer - put VCR under lump hammer - replace with Humax PVR8000T
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,259
    Rainham Essex
    +2,403
    :nono: Now, now Martin. A VCR is not all Bad. nearly, but not all :devil: - Should get a TiVo instead :thumbsup:
    The chances are that a scart cable that is not full wired could cause this. It could be an RGB scart or could be directional, try swapping the ends around. But your best bet is to replace with a fully wired scart cable.
    The other thing to check is that most VCRs have more than 1 AV channel. Have you selected the correct AV channel for the scart socket that the Freeview box is connected to?
    Mark.
  4. figrin_dan
    figrin_dan
    Jan 9, 2003
    2,038
    +154
    All SCARTs carry the composite signals for VCR recording. Even if they are labelled RGB (The R is the same wire as composite and C on S-video).
    Are you getting sound?
    Try tuning your tv to the vcr (ie bypassing the VCR - TV SCART) to see what it's getting.
