How to Record 1 Freeview channel and view another simultaneously?
Discussion in 'Freeview & YouView' started by cjm, Aug 31, 2005.
  1. cjm
    cjm
    Have just acquired the Panasonic Plasma 42"PV500B (with built in Freeview receiver) and DMR-EH50 Hard Disk Recorder to complement it. Seems great but am already frustrated that I cannot record one Freeview Channel and watch another at the same time.
    If I just buy and plug in another freeview box will this simply solve the problem or is it just not that easy. I guess my worry is that that even if it works in theory there will be contention between the recorder and the 2 freeview tuners and a difficult to use mess will result.
    Any advice from those that know or have done it greatfully received.
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Most of use use a Freeview DVR - in your case get a cheap FV box
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    With Freeview boxes at £29.99 at Argos, it's hardly going to break the bank :)
