How to put protected WMA files onto iPod?
Discussion in 'Headphones, Earphones & Portable Music' started by jonny round boy, Dec 29, 2006.
Tags:
  1. jonny round boy
    jonny round boy
    Oct 25, 2006
    194
    Halifax, West Yorkshire
    +12
    Got the g/f a 4GB Nano for christmas - set up iTunes etc no problem.
    There was an album she wanted, but Woolworths had it for download cheaper than iTunes, so she bought it & downloaded it. Trouble is, it's a protected WMA format. I've tried importing it to iTunes, but it says it can't import protected files.
    How do I convert protected WMA files to AAC?
    I even tried burning the WMA files to audio CD so I could import it that way, but that didn't work (I think my CD drive is faulty, doesn't want to write CDs half the time).
    Any ideas how I can get this on?
  2. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    You could record each track using Windows Sound Recorder as it's played in Windows Media Player if your sound card offers the Wave Out Mix as a recordable input (i.e. a loop-back). Do a Save As for each file and click on Change... button to set MP3 format (which the iPod will play OK).
  3. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    Burn the files off to CD (protection allowing) then re-rip them from the CD
