MasterMark
Hello all! Apologies for the length of post, but figured it was best to describe everything.Any tips/suggestions would be massively appreciated!
So, historically had Sky HD, with a RF/Coax cable chased through the wall so I could watch the same channel in the kitchen. Kitchen & lounge are open, but I can't see the tv from the kitchen so with an additional small tv in the kitchen, perfect way to watch while cooking and move seemlessly betwee the two.
I've now made the mistake of upgrading to Sky Q
I've tried with an HDMI splitter and a long 15m HDMI cable. Works absolutely fine. But I can't use the existing cable routing because they didn't use a conduit and the cable is cemented into the back-box, and despite my best efforts, I can't loosen it.
So another option - Sky coax cables currently run hidden (i'm guessing under skirting boards) to the dish just outside the lounge (on the wall off a flat roof, so easily accessible). It's about a 5m run. So I guess 2 questions:
1) What is the best way to pull and HDMI or Cat6 cable through? I guess I'd need to tape it to the existing Sky coax, then pull everything through from the outside, and then try and pull the coax cables back in? If I get the (waterproof) cable outside, I can run it for another 5 or 6 metres and drill a hole straight into the kitchen.
2) Assuming I can actually pull and HDMI through (hoping it's not too thick), am I better off using HDMI splitter and 15m HDMI cable, or running a Cat6 with HDMI extender/Baluns on either side? Amongst other things, wondering there'd be any difference in terms of sound/picture lag given I can "hear" both TVs. Just HD, not 4K.
Thank you for any tips!
