How to protect lens?
Discussion in 'Projectors, Screens & Video Processors' started by Fonzerelli, Jun 21, 2004.
  1. Fonzerelli
    Fonzerelli
    Jan 19, 2004
    159
    I have a panny PTAE300 and the lens is a dust magnet :( is there some sort of cover i can use on it for use when the projector is on? a bit like a camera filter.
  2. pcdoc
    pcdoc
    Feb 11, 2003
    140
    +3
    I have the HMC FL-day filter on my PTAE100 which really helps the picture and protects the lens.
  3. Fonzerelli
    Fonzerelli
    Jan 19, 2004
    159
    how does it help the picture mate?
  4. pcdoc
    pcdoc
    Feb 11, 2003
    140
    +3
    hi fonz....It helps with the contrast seems to make blacks blacker. There used to be a big thread on here about the filters have a search see if they are still there. Got my filter from USA, had to fit it using some insulating tape. Hasn't fallen off yet :D
  5. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Fonz,
    There's a link in the FAQ to info about the Hoya FLD................ as well as links to all sorts of other good stuff.
    Sean G.
