How to preset FM/AM stations manually on KLH receiver R-3100?
Discussion in 'AV Receivers & Amplifiers' started by shrsmas, Feb 27, 2005.
  1. shrsmas
    shrsmas
    Just got the receiver, no manual, no remote control.
    Tried for a while, but still couldn't figure out how to preset radio stations from buttons on the front panel.
    Also, anyone knows the remote control code for this product? :lease:
    Thanks!
  2. wellstonok
    wellstonok
    Nov 18, 2016
    4
    Oklahoma
    I have a KLH r3100, you will have to purchase a remote. There is no way to set the presets without a remote. On the remote you have a memory button, set the receiver to the station desired, press the memory button, then press the number on the remote to the preset number you want, 1, 2 etc.
