How To Play .TS
Discussion in 'General TV Discussions Forum' started by Silentbob101, Oct 21, 2005.
  1. Silentbob101
    Silentbob101
    hi i have dled some .ts files that make a 40 min video but is split into 10-15 .ts files i can play each fine. but i have to watch each sepratly do i need to join them all up or do i need to do somthing specil to get it to work thanks in advance ... chris
  2. indie24
    indie24
    Oct 3, 2004
    994
    london
    +262
    i use power dvd or theatertek to view my ts files. I use a program called simple file joiner which is free to get (do google search) to join all my ts files together. Quickest way of doing it
  3. stevebrowne
    stevebrowne
    I just do this: copy/b *.ts
    Worked for everything so far...
  4. xela19115
    xela19115
    Apr 26, 2005
    2
    Northampton, PA, USA
    Download VLC player. It's free and very good. http://www.videolan.org. Or you can also check out this thread: http://www.avsforum.com/avs-vb/showthread.php?t=399319.
    Good luck.
  5. RockySpieler
    RockySpieler
    May 23, 2005
    1,661
    Snaking the Lineup
    +115
    VLC is great, no need to join files, just use open directory option. Also plays DVD's, AND incomplete BT's!
