how to play multiple .ts files
Discussion in 'TVs' started by tim k, Sep 4, 2005.
  1. tim k
    tim k
    I've decided to start backing up all my .ts files as im simply running out of room, and having to delete them. so i have to split them into dvd (4.7gig) files, so around 2-3 discs each movie. how can i play these (when on the hard drive) so they play simulatenously?? I have found wmp classic to be the best player (no stutter) is there anyway to get them cued up in this player??
    also any other hints on backing up .ts files?
  2. mjn
    mjn
    May 24, 2001
    18,230
    Herts, England
    +5,253
    Can't you just queue the files in Winamp?
  3. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    join them back together? into one big file
  4. meansizzler
    meansizzler
    May 11, 2005
    7,582
    104
    London
    +266
    well install win dvd 7 and register .ts files to play back in media player 10 and they should play fine, when you stick in your CD, and the autorun window comes up select to "Play in Media PLayer" and away you go..., then just swap the disc for the next one...
  5. dan1979
    dan1979
    Sep 16, 2004
    3,520
    83
    +201
    I use a program called Simple File joiner to join .ts files works perfectly.
  6. tim k
    tim k
    no im using hdtvtompeg to join, thats working fine, i just mean its easier for me to just split it into 4.7gig files then i can watch it once, then burn it. i just need a program that will play the .ts files in order off the hard drive, comprende?!
  7. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Don't use WMP (prefer VLC) but creating a playlist that can be read by WMP isn't that difficult. You'll find the basics in the wmp help file.
  8. petecowie
    petecowie
    R.I.P.
    Sep 3, 2003
    871
    2
    Essex
    +43
    I would suggest to anyone joining tohere ts files together to keep them below 2gb that way they are iso and udf compatible. For example the Jap Linkplayer2 can only handle ISO disks at present and so all my UDF disks with 4.7Gb TS files won't play direct through the player.
  9. Pygmy Hippo
    Pygmy Hippo
    I've been using HDTVtoMPEG2 too, but have heard some people saying that it may degrade the picture quality if i do this - does anyone have a definitive answer?
    (I'm only on a small screen at the moment and won't be able to see any real degradation - don't want to knacker all my stuff when I go big next year!!) :thumbsup:
  10. wilno
    wilno
    Feb 14, 2005
    Theater Tek will play them, no need to join them up just have them all in the same folder.
  11. scumball
    scumball
    Jan 12, 2004
    6,233
    Harrow - London
    +412
    No just keep them as .ts files - there are purely joined not re-encoded.
  12. aligebes
    aligebes
    Jan 2, 2004
    229
    Edinburgh, Scotland
    +3
    There is a command line prompt you can use to join all the .ts files into one big file, But I can't remember what it is!!
    www.altbinarieshdtv.com forums section had it on there, but a search in google will likely produce the same results.
  13. Tony Hoyle
    Tony Hoyle
    Aug 4, 2005
    3,347
    103
    Stockport
    copy/b *.ts bigfile.ts
    .. should do it, but you're not guaranteed to get the files in the correct order (should do on ntfs though I think).
    Newsbin pro has a nice file joining app builtin too.
  14. Lide
    Lide
    Sep 2, 2005
    253
    16
    You want help in how to play illegally downloaded files? :rolleyes:
  15. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    I use media player 10 for multiple files just drag them into the playlist and play them.
  16. probedb
    probedb
    Aug 20, 2003
    2,653
    Sheffield
    +181
    Where did they say they were illegal downloads? They never said where they came from or what they're of.
    Incidentally, HDTV2MPEG is very good just don't convert them to MPEGs, leave them as transport streams as it screws them up sometimes. Media Player Classic is very good for playing them as well :)
