How to play avi/xvid/divx files in Media Centre?
Discussion in 'Desktop & Laptop Computers Forum' started by Devster1, Jan 22, 2008.
  1. Devster1
    Devster1
    Jan 12, 2007
    60
    Does anyone know how to get avi files to play in Windows Media Centre on Vista 32-bit?
    Has anyone managed to get this working??!! :suicide:
    I have tried a few avi files I would like to play in Media Centre, but when I go to the directory in MC that contains the avi files, MC states that no videos were found? I have tried installing ffdshow and media control plugin, but I still cannot get MC to recognise my avi's :confused:
    Its driving me nuts, I am sure there are many other people who would like to get this working, someone please help! A 'How to' guide from someone would be splendid :thumbsup:
    :lease::lease::lease:
  2. md1542
    md1542
    Jul 13, 2005
    312
    28
    Gloucester
    +54
    By default, you can't. Windows Media Center doesn't support Xvid or DivX files. However, there's a 3rd party plugin you can use that apparently does the trick. You can download it here:
    http://damienbt.free.fr/index.php#download
    If you want to read about it first, check this "review" out:
    http://www.onetipaday.com/2007/05/28/how-to-play-xvid-and-avi-files-with-vista-media-center/
    I've never tried it myself, as I used WMP11....but according to those sites - it does what you want. Would be interested to see the result, so let me know how it goes!
  3. tinners
    tinners
    May 22, 2006
    3,288
    Bucks
    +242
  4. Devster1
    Devster1
    Jan 12, 2007
    60
    This is exactly what I have tried. It didnt work :thumbsdow
    The media control never worked, and after installing ffdshow, Media Centre wouldnt even play mpeg videos (it did before). It caused media centre to crash saying the ffdshow codec was the problem.
  5. Devster1
    Devster1
    Jan 12, 2007
    60
    Thanks tinners, this looks interesting. Could you give a few more steps on how to do this? Also I presume a codec pack is required to play all these file types?
    Or can I just modify the registry and thats it?
  6. tinners
    tinners
    May 22, 2006
    3,288
    Bucks
    +242
    you should only need ffdshow (You DONT need mediacontrol) to play DIVX XVID etc.
    Uninstall ffdshow, mediacontrol and then just install
    http://ffdshow-tryout.sourceforge.net/
    Check you can play all your files in Windows Media Player. If so then your codecs are OK.
    Then run the registry changes and the files should appear in the videos area of media center. Again you can check this by adding the folders in Windows Media Player and seeing if the files show up.
    MediaControl allows ffwd / rewd in media center. Works OK on my HTPC with ffdshow tryouts. Only install this when all else is OK.
  7. Devster1
    Devster1
    Jan 12, 2007
    60
    thanks tinners, it worked :thumbsup::thumbsup:
    I have only tried .avi files so far and couldnt believe my eyes when they showed up in MC :eek:
    Just got to go through now and add all the file types to the registry and install ffdshow !
    cheers :smashin:
  8. J7MAN
    J7MAN
    Oct 28, 2007
    976
    Mansfield, Notts.
    +75
    Strange, my VMC always plays .avi's. Only had to add .mkv's to the registry.
  9. Stiggy
    Stiggy
    Dec 7, 2004
    6,725
    Sandy Heath
    +1,043
    Some of you seem to be making this overly complicated. To play DivX/Xvid, just download and install the DivX/Xvid codec! I had problems with the latest version of DivX, but Xvid works fine.
  10. y2k
    y2k
    Jan 3, 2008
    3,300
    Banana Republic
    +291
  11. tinners
    tinners
    May 22, 2006
    3,288
    Bucks
    +242
    but that's not in media center ;)
  12. y2k
    y2k
    Jan 3, 2008
    3,300
    Banana Republic
    +291
    :oops: again
  13. SHAHZ
    SHAHZ
    May 6, 2006
    24
    Thanks for the link tinners, just what i needed:thumbsup:
  14. beltona
    beltona
    May 5, 2008
    hi there new to this having the same problem.did you get it to work if so could tell me how ,many thanks helen
  15. Devster1
    Devster1
    Jan 12, 2007
    60
