how to play .avi or .wmv files one after the other
Discussion in 'Desktop & Laptop Computers Forum' started by Ray, Aug 8, 2005.
  1. Ray
    Ray
    Oct 2, 2002
    854
    West Yorkshire
    +23
    I'm running on plain old XP not MCE or Meedio etc. Is there a way to create a playlist of sorts so I can run thru a number of avi or wmv files one after the other ? e.g HiDef trailers , clips etc.
    Ray
  2. Fast Jon
    Fast Jon
    Dec 8, 2004
    260
    +10
    Assuming that you're using Media Player, just create a playlist then drag & drop your media files to the playlist. Sort as required.
    Apologies if this isn't what you're trying to do.
  3. Ray
    Ray
    Oct 2, 2002
    854
    West Yorkshire
    +23
    It was and I was being stupid for not trying it in Media Player before asking the question! Doh!
  4. The Dude
    The Dude
    May 21, 2004
    5,127
    Beverley, East Yorkshire
    +1,404
    it's even easier than that... just select all the files you want to play, right-click, and 'queue it up'
  5. Ray
    Ray
    Oct 2, 2002
    854
    West Yorkshire
    +23
    So it is - thx.
    Think I'll still set up some individual playlists for different hidef demos plus the old pearl and dean stuff.
    Ray
