how to place a center on a RP?
Discussion in 'Home Cinema Speakers' started by mutley, Feb 3, 2003.
  1. mutley
    mutley
    Jul 28, 2002
    445
    Portugal
    How do you place the center speaker on a RP like Sony 44PX2?
    Can't be below, the top isn't regular.....
  2. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    [​IMG]
    [​IMG]
    I've used it like that for 4 years with no problem, however I don't have unruly kids or pets to dislodge it :nono:
    My TV is the Toshiba 43" RPTV.
  3. chris
    chris
    Nov 20, 2000
    1,209
    romney marsh, kent, uk
    +28
    I just put a shelf up behind the TV........
    Looks and sounds ok......evern the misses was inpressed.
    I also had to put 4 shelfs up, next to the TV for the A/V kit.......did not fancy going out and spending £200 or more on a A/V rack, with my kids running around.
    The misses evern liked the look of these, once i'd finished.
    And it was £160 cheaper than a rack.
  4. jim.rae
    jim.rae
    Whatever solution you use, pop four pieces of blue tack under the speaker and it will never move again...
  5. mutley
    mutley
    Jul 28, 2002
    445
    Portugal
    when it's a B&W LCR600 - 350mm deep don't think it's tat easy....
  6. EvilMudge
    EvilMudge
    Yeah, Phil's (and mine because I have the same centre) is only 261mm deep.
    BTW the LCR600S3 is only 311mm deep according to B&W.
  7. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    I'm screwed when the Studio CC arrives though, at 30cm deep it's doubtfull if I can still place it on the TV :( :rolleyes: :)
  8. EvilMudge
    EvilMudge
    It also weighs quite a bit more than the old CC-350 - and that's currently crushing my old TV. At least all that weight is going to good use, and should make it more stable if it balances properly. Wouldn't like to see your face if your HGS wobbles it off the top and it goes through your TV though!:eek::mad:
    Oh dear, what am I going to do when I order the complete Ref set for my new pad.:D
  9. nathan_silly
    nathan_silly
    I've got a Kef Model 200, no way I can put this ontop of my Toshiba 42PW23P. At 11kg, it might bend the screen.
    The top is only a couple of inches deep, even with blu-tack it'll still be very unstable.
    Reckon I would need to use double sided sticky pads.
    Another alternative is using a single speaker stand, place that in front of the set, and centre just under the screen.
  10. Anodyne
    Anodyne
    Dec 4, 2002
    552
    46
    Bristol
    +134
  11. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
  12. damtom1
    damtom1
    I,ve got a Mission M7C2 perched on top of a sony KP44PX2.The front of the speaker is flush with the front of the tv,with a line of blu tack under the front.Supporting the rear of the speaker,ive got a wedge of polystryne between the top/back of the tv and the base of the centre speaker.The weight of the speaker and some more blu tack keep the"wedge" from going anywhere....nice and steady:cool: ...so far!
