Deleted member 134693
- Joined
- Jun 13, 2006
- Messages
- 13,523
- Reaction score
- 3,413
- Points
- 3,158
Hello.
I've got 3 nest thermostats installed at home but one kept going offline so I couldn't do anything with it via the app.
I've just come off a chat with Nest and they've asked me to unplug various items in my house as they thought it was an interference issue. Up on unplugging the ethernet lead connected to my POE adaptor the nest come back online. As soon as I plug the lead back in to the router it goes off so I'm 99.9% sure this is the issue!!
I'm limited by my ISP so pretty much stuck with sky and using one of their hubs at the moment. I'm using TP link POE adaptors and my CCTV is HiKvision.
I've not had time to change anything yet - like a direct cable to the DVR rather than using POE - but the way my house / rooms are I'll most likely need to use POE of some sort.
I'm also considering changing my router as a few people have said the TP Link AC 1200 is a much better router but will it solve any interference issues...?
Or is there a simple setting I can change with my current system that may stop the interference??
Thanks for any help anyone can give me - its all a little over my head at the moment!!
