How To Operate Your Amp Via Sky Remote
Discussion in 'Sky Digital TV Forum' started by F1T, Sep 17, 2007.
  1. F1T
    F1T
    Feb 25, 2007
    29
    I dont know if this has already been posted but it is handy :thumbsup:
    Worked on my Yamaha amp :clap:
  2. Bagger
    Bagger
    May 8, 2007
    2,225
    Leicester
    +227
    Its in here all ready, some where lol
    i used it a few months ago to set it up with my denon, works a treat :)
    Ort to made a sticky
  3. WilliamTM
    WilliamTM
    Apr 7, 2007
    374
    2
    Stafford
    +37
    I'll try this tomorrow with my amp. So far I can control the volume with the amp's remote, the MCE remote, and my Logitech Harmony..soo..one more will be even better. :D
  4. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    William I take it you like Sony!!:D
    I have the same TV and also the 970 recorder as well as sky HD. Hopefully will add new kefs and onkyo amp soon!!:D
    I will obviously have to use this for the sky remote as it is always useful.
  5. WilliamTM
    WilliamTM
    Apr 7, 2007
    374
    2
    Stafford
    +37
    Yep, I'm a massive Sony fan. :D
    I just don't like the way some of their stuff is a bit overpriced. :(
  6. nwpsys
    nwpsys
    Oct 11, 2001
    100
    +4
    Just in case anyone is struggling with a Denon amp, I found at Digitalspy that someone used the code 1388. I tried this with my AVR-2801 and this worked, where the two code listed above did not.
    nwpsys
  7. AndyC111
    AndyC111
    Feb 19, 2007
    63
    can someone advise me please if after doing this programming for your amp will it still control your TV functions (e.g. volume)? Or is it a case of one or the other? Cheers
  8. nwpsys
    nwpsys
    Oct 11, 2001
    100
    +4
    With mine, the vol up down buttons on the remote continue to control the tv after the programming. It is the blue triangular up and down arrows that control my amp volume. The left blue triangle toggles them amp in and out of standby, and the right one mutes the amp.
    nwpsys
  9. pcbbc
    pcbbc
    Jul 23, 2003
    397
    28
    London UK
    +84
    Yes, the volume will still work for the TV via the volume control. Up+Down in TV mode control the AV Amp volume. Left is power and I think right is mute.
    There is also a "punch through" feature which will reverse the above. This means that the volume controls will control the AV amp volume in TV and Sky mode.
    This is probably the most useful if you use the AV Amp all the time, as volume on Amp can be adjusted without switching to TV mode.
    To program punch through:
    Press TV
    Hold SELECT and 1 until the light blinks twice.
    To undo this feature:
    Press TV
    Hold SELECT and 0 until the light blinks twice.
    Original details courtesy of AlanJ and abailey at DigitalSpy and Automan's website.
  10. AndyC111
    AndyC111
    Feb 19, 2007
    63
    Excellent, thanks for the replies guys.
  11. sameerabedi
    sameerabedi
    Feb 17, 2006
    258
    +4
    Presumably you can't control the TV volume anymore if your controlling the amp?
    Also, anyone have a code for an Onkyo Amp?
  12. Drav
    Drav
    Aug 26, 2007
    32
    I dont suppose anyone has a code to work with a Sony HT-SS1100? none of the above sony codes seem to work. :(
  13. pcbbc
    pcbbc
    Jul 23, 2003
    397
    28
    London UK
    +84
    If you are in Sky mode you can control EITHER the TV volume OR the AV Amp volume, depending on the punch through setting - but not BOTH.
    When you are in TV mode, you control BOTH volumes. Which is controlled by the standard volume controls will be set as per the punch through setting. The other device will be controlled by the UP/DOWN cursor keys.
    Edit: One for All lists the following code for Onkyo receivers:
    Onkyo 0135
    One for All are owned by Universal Electronics, who also make the Sky remotes. The Sky remotes therefore use the same codes, just with 28 added (presumably to try to disguise this):
    To convert from a OneForAll code to a Sky code - Add 28
    To convert from a Sky code to a OneForAll code - Subtract 28
    So you should try 0163
  14. DJMS
    DJMS
    Jun 6, 2007
    794
    28
    Kent
    +72
    Anybody got a code for Cambridge amps? :lease: Tried 0189 as this was mentioned on another post but it didnt work :(
  15. bobturbo
    bobturbo
    Jun 5, 2006
    55
    I tried this on my setup and when I pushed the button to enter the last digit of the 4 digit code it just changes my tv channel - tried 4 times now and it does exactly the same each time
  16. WilliamTM
    WilliamTM
    Apr 7, 2007
    374
    2
    Stafford
    +37
    Just tried it - doesn't work (old Sony amp).
    Doesn't bother me that much though as I only ever use my Logitech Harmony remote, or the MCE remote.
  17. rob virgo
    rob virgo
    Nov 27, 2004
    218
    16
    f1t ,
    i have a dsp 759 and it doesnt work for me,any other codes to try
    cheers
    zaga
  18. PKingham
    PKingham
    Sep 20, 2007
    4
    Tried this in my JVC home cinema and worked first time
    Thats all my remotes tucked away and just my sky left out. possibly the best tip I've heard
    thanks
    Paul
  19. vwchris
    vwchris
    May 7, 2007
    65
    Manchester
    +8
    :smashin::smashin: Just tried this on my 3 year old Panasonic home cinema, last code in the list did the trick.
  20. anticlaus105
    anticlaus105
    Nov 11, 2004
    1,110
    63
    +163
    Cheers fot that. Worked a treat (3806).
    Anyone know if there is a button to switch the input e.g from DVD to TV?
    EDIT: Seems rewind changes switches modes e.g stadium, matrix, wide screen etc and record button put to DBS input (doesn't cycle it tho).
  21. pcbbc
    pcbbc
    Jul 23, 2003
    397
    28
    London UK
    +84
    0189 is the one for all code. You need to add 28 for the Sky+ remote. Try 0217.
    Which model of Sky remote do you have? This only works on Sky+ remotes.
    One for all codes for Yamaha are 0176 and 0186, so try 0204 and 0214.
  22. pcbbc
    pcbbc
    Jul 23, 2003
    397
    28
    London UK
    +84
    Here is an updated list of the codes.
    I have added the One 4 All setup codes converted to Sky codes (shown with a +) in the hope they might be of use. They may not work on some or all Sky+ remotes, but at least they are a starting point.
    Code:
    Adc 0559+
    Aiwa 0149 0186 1433 0433+ 0217+
    Akai 0143 0468 0374+ 0637+
    Alba 0587
    Amstrad 0830 0772
    Anam 0309+ 0637+
    Arcam 0669 0297 0670+ 0217+
    Audiolab 0297 1217
    Bang & Olufsen 0827+
    Bat 0297
    Brandt 0852+
    Bush 0297 0449 0875
    Cambridge Audio 0217+
    Capetronic 0559+
    Carver 0070+ 0388+ 0297+ 0036+ 0217+
    Casio 0223+
    Clarinette 0223+
    Clatronic 0772
    Curtis Mathes 0328+ 0108+
    Denon 0032 0188 0301+
    Elta 0772
    Emerson 0452+
    Fisher 0070+ 0388+ 0247+
    Garrard 0468 0772 0309+ 0314+ 0452+ 0491+
    Ge 0106+
    Genexxa 0468 0214+
    Goldmund 0297 0217+
    Goldstar 0309+
    Goodmans 0468 0772 0449 1081 0637+
    Grundig 0297 0875 1217 1117 0772 0217+ 0314+ 0309+ 0247+
    Harman/Kardon 0138 0217+ 0236+
    Harwood 0772
    Inkel 0055 0530 0519+
    Intersound 0772
    Jbl 0138
    Jvc 0102 0492 0359+
    Kenwood 1055 1341 1597 0341 0342 0055 0214+ 0267+ 0384+ 0105+
    Koss 0772 0452+
    Lg 0309+
    Linn 0297 0217+
    Lloyd'S 0223+
    Luxman 0193+
    Lxi 0772 0209+
    Mafui 0342
    Magnavox 0297+ 0217+ 0223+ 0559+
    Marantz 0297 1117 1217 0217+ 0440+ 0247+ 0349+ 0067+
    Mark 0297
    Matsui 0772
    Mcs 0067+ 0374+
    Memorex 0042+
    Meridian 0297
    Micromega 0297 1217 0217+
    Minton 1123
    Mitsubishi 0468
    Modulaire 0223+
    Mx Onda 0772
    Myryad 0297 1217
    Nad 0348+
    Naim 0297
    Nakamichi 0349+ 0375+
    Nec 0292+
    Nikkei 0772
    Ntde 0772
    Okano 0468
    Onkyo 0163+
    Optimus 0041+ 0328+ 0423+ 0070+ 0214+ 0108+ 0205+ 0209+ 0247+ 0559+ 0698+
    Orient Power 0772
    Pace 0828
    Panasonic 0336 1336 1337 1546 0337+ 0546+ 0791+ 0067+
    Penney 0223+
    Philips 1117 1217 0669 0297 0217+ 0440+ 0670+
    Phontrend 0530
    Pioneer 0297 0317 0042+ 0108+ 0214+ 0041+ 0328+ 0178+ 0559+ 0658+
    Pye 0875
    Quad 0297
    Quasar 0067+
    Radioshack 0772
    Rca 0374+ 0082+ 0388+ 0559+
    Realistic 0423+ 0191+ 0209+ 0223+
    Revox 0297 0217+ 0214+
    Roadstar 0875 0374+
    Saba 0852+
    Saisho 0374+
    Samsung 0314+
    Sansui 1117 0217+ 0637+ 0374+ 0349+
    Sanyo 0772 0388+ 0247+ 0070+
    Schneider 1081 0138 0772
    Scott 0191+ 0350+
    Sharp 0214+
    Sherwood 0530 0519+
    Shure 0292+
    Siemens 0637+
    Sonic 0309+
    Sony 1086 1186 1286 1786 0186+ 0443+ 0248+ 0717+ 0502+
    Soundesign 0239+ 0106+ 0698+
    Soundwave 0637+
    Taekwang 0468
    Teac 0449 0637+ 0138+ 0191+ 0491+
    Technics 1336 1337 1546 0337+ 0546+ 0791+ 0236+ 0067+ 0336+
    Techwood 0309+
    Telefunken 0875 0852+
    Thomson 0852+
    Thorens 0297 1217 0217+
    Thorn 0772
    Uher 0374+
    Universum 0297 0772 0468 0309+ 0637+ 0314+ 0217+
    Victor 0102 0359+
    Videologic 1123
    Wards 0041+ 0239+ 0106+ 0042+ 0186+ 0070+ 0082+ 0108+ 0217+
    Wharfedale 0468 0637+
    Yamaha 0204 1304 0214+ 0161+ 0382+ 0171+ 0532+
    Yorx 0223+
    Zenith 0772 0309+
  23. F1T
    F1T
    Feb 25, 2007
    29
    I'm glad some found this useful, I am not an expert on this, I just picked it up somewhere else.
    Did anyone find which button changes from external decoder (dvd) to tv for a yamaha amp?
  24. gmp
    gmp
    Mar 23, 2006
    479
    28
    +47
    Been through this and other posts (along with one 4 all site) but still can't find code to control LG sh502ht home cinema all in one. Anyone found it by chance or know any other code lists worth a look?:hiya:
  25. CJSIMPSON
    CJSIMPSON
    Jan 17, 2006
    756
    +4
    I have just tried this for my quite old pioneer amp its a vsx-c100 and it doesnt work. In fact the first code 0297 isnt recognised for some reason and the second doesnt work. Anybody have any ideas which code might work?
  26. CJSIMPSON
    CJSIMPSON
    Jan 17, 2006
    756
    +4
    Just done a bit of searching and found the page this must have been from word for word and they have added and removed some codes so here they are. And the new code for Pioneer added worked for my amp.
    New codes:
    Make Code
    ? 0163
    ? 0171
    Pioneer 0328
    ? 0349
    ? 0382
    ? 0388
    ? 0505
    Sherwood 0519
    Sony 0717
    ? 0869
    ? 0870
    ? 0876
    ? 0899
    ? 1027
    ? 1051
    ? 1132
    ? 1188
    ? 1212
    ? 1282
    ? 1382
    ? 1388
    Deleted codes:
    Make Code
    Inkel 0055
    Kenwood 0055
    Aiwa 0186
    Sony 0186
    Arcam 0297
    Audiolab 0297
    Bat 0297
    Bush 0297
    Goldmund 0297
    Grundig 0297
    Linn 0297
    Marantz 0297
    Mark 0297
    Meridian 0297
    Micromega 0297
    Myryad 0297
    Naim 0297
    Philips 0297
    Pioneer 0297
    Quad 0297
    Revox 0297
    Thorens 0297
    Universum 0297
    Panasonic 0336
    Kenwood 0341
    Kenwood 0342
    Mafui 0342
    Pace 0828
    Amstrad 0830
    Goodmans 1081
    Schneider 1081
  27. Cloverleaf
    Cloverleaf
    Jan 13, 2008
    992
    East, East, East London
    +42
    Good tip - thanks !!! Found that 1786 works for my Sony
