How to make my original dvd to divx?
Discussion in 'Xbox Forums' started by delboyuk2005uk, Dec 28, 2006.
  1. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    Hi am looking to rip all my dvds onto my hard drive and them convert them to divx. out of you experinced computer boffins can anyone recommend me the best program software to rip my dvds onto my hard drive then convert them over to divx.
    also what will be the best settings to use when converting to divx
    many thanks
  2. edent
    edent
    Mar 30, 2005
    345
    Oxford
    +18
    I wouldn't.
    When you convert to DivX you're going to lose image and sound quality. Unless you want to take your movies with you on a portable player, this is what I'd do.
    1) Get a big HDD. You can get 500GB for ~£115 (http://svp.co.uk/products-solo.php?pid=1728). Your average DVD movie is 4.7GB - so you can fit around 100 on a single drive - uncompressed.
    2) To save space, use DVD Shrink (http://www.dvdshrink.org/). Use it to strip out soundtracks and subtitles that you won't use (are you ever going to want the 5.1 German Dubbing and Swedish subtitles on Jackie Chan's First Strike?). You can also use it to strip out the trailers, special features, menus etc.
    3) You can use DVD shrink to lower the size of the video. It will keep it as MPEG which will be compatible with any DVD player if you want to burn the movie to disc.
    4) If you really want to go down the DivX route - go to http://www.doom9.org/ and read up. There are a number of guides and settings and automated programs - but you'll always end up with lower quality than taking a straight rip.
    T
  3. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    well i got a 200gig hard drive in my xbox and want to put them on there.
  4. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    how do i rip the normal dvd onto my pc?
    dont they have security on them?
  5. speedwell
    speedwell
    Nov 9, 2006
    23
    4
    Haha.
    Yes they do. But it was cracked ages ago. dvd shrink does it (also many other programs).
