How to make best use of my MCE PC
Discussion in 'Microsoft Windows' started by dUnKle, May 21, 2005.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    13,618
    +1,455
    At the moment I have two PCs - my main one is a 3800+ 1024 MB Ram with 2 x 6600GT in SLI
    The second PC is a 2.6GHz P4 with 1024 Mb Ram and a Rad 9800 Pro
    My intention was to use the older PC as my HTPC and connect it via DVI to my 42PD5200
    However I now wander if the following would be possible
    Could I connect the output of the 2nd 6600gt via VGA to the TV and have one PC that does everything ?
    I still use my PC at back of room (main PC) for games and word processing but if I install it with MCE could I run two outputs - each being optimised for the displays - or would I be better off running two seperate PCs ?
