How to make a Sony 730 Multiregion?
Discussion in 'Blu-ray & DVD Players & Recorders' started by churchwa, Dec 31, 2003.
  1. churchwa
    churchwa
    Does the hardware have to be changed or is it a software hack? I just wanted to know becasue the region 2 players are cheaper than the MR ones and if it is only software that need changing it might be possible to do it myself.
  2. t-force
    t-force
    May 2, 2001
    1,745
    Southampton, UK
    +99
    As far as I'm aware, it's a hardware only mod I'm afraid, in common with all Sonys.
  3. churchwa
    churchwa
    Thanks for the quick response!
    No it is just a matter of finding the cheapest place to buy the multi region from. The best so far is Techtronics @ £133.49 delivered. Any better than that?
  4. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
