How to make a boot CD
Discussion in 'Desktop & Laptop Computers Forum' started by jlcrawford, May 19, 2002.
  1. jlcrawford
    jlcrawford
    Mar 21, 2001
    491
    NE England
    +3
    Sorry if this is off topic but how do I make a boot CD?
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    The following is taken from the help on Nero5 software. If you are not using Nero then check the help on the software you are using. It'll be there somewhere -
    Bootable CDs may be created only under Windows 95/98or NT.
    1.First step is to create a new bootable ISO compilation. This can be done by clicking the menu command „File" -> „New...".
    2.On the left side of the dialog please choose the icon „CD-ROM (Boot)".
    3.At this point you can see the property page „Boot". The upper part of this page is used to select the kind of model you have as input for the bootable CD. You can choose whether you want to use a logical drive or an image file as model for your bootable CD.
    Note: If the desired input device does not appear in the list of possible model drives then the reason is probably the size limitation for bootable CDs. The logical drive's size may not exceed the capacity of a CD; that means 640MB.
    Note: Please consider that you need to have administrator rights to be able to create bootable CDs using Windows NT 4.0. This behaviour is by Microsoft's operating system design and was chosen to prevent hackers from accessing other user's (possibly secret) files. But to create bootable CDs all sectors of a logical drive must be accessible. And the only user who's got the permission to read all sectors using Windows NT is the supervisor.
    4.The lower part of the boot property page contains detailed settings for bootable CDs. These settings normally are dimmed indicating that Nero will check and set all the expert options automatically for you. If you choose to use an image file as model for the creation of a bootable CD, then Nero can't automatically choose those settings for you. In this case, or if you choose to define these settings manually, you can do so. Of course you're responsible for the resulting CD. If the settings are incorrect you will get an incorrect bootable CD...
    5.You can now click on New. The ISO compilation window opens.
    6.If the File Browser has not yet been opened, you can do that now by entering the VIEW>New File Browser command or by clicking on the File Browser icon.
    7.Click on the desired data files in the File Browser with the mouse and then drag them into the compilation window.
    Note: you can burn a bootable CD without data on it. In that case, you don't have to compile files.
    8.Now open the Write CD dialog. The easiest way to do this is to click on the Write CD icon in the toolbar. You will then go to the Write CD dialog box, which will undoubtedly look familiar to you:
    9.It is the same box which you saw for the creation of a new compilation, only now the Burn property sheet is shown on the top.
    You will see several boxes, of which some have already been selected. All of the preferences may now be examined and changed if necessary.
    10.Confirm by clicking on Write.
