how to make a 3802 remote work a sony tv
Discussion in 'AV Receivers & Amplifiers' started by Curry Monster, Mar 23, 2006.
Tags:
  1. Curry Monster
    Curry Monster
    May 18, 2005
    5,455
    +258
    Help!
    My sony 17" LCD remotes gone walkies and I cant get the sky+ remote to bring up the menu to reset the channels(I unplugged it!)
    I have a RC884 remote from my denon 3802...is it possible to get this to work the tv
  2. Miniholic
    Miniholic
    Apr 26, 2001
    3,060
    The Shire
    +399
    I think you'll be struggling to be honest, I use the Denon remote occasionally for my old Sony TV (4:3 CRT) and it only controls the basic functions (volume control also stays with the amp), not the menus.
    EDIT: Have you got the remote codes? I've got the code sheet somewhere if you need it.
