How to know which CD-Rs last longest?
Discussion in 'Music & Music Streaming Services' started by SyG, Jul 24, 2005.
  1. SyG
    SyG
    Apr 24, 2005
    138
    After hours of research on the net, I have found that in terms of CD longevity, there are three standards:
    Metal-Cyanine Blue Original CD-R Dye, Least stable
    Metal-Azo Very Deep Blue Increased stability over Cyanine dyes
    Phthalocyanine Very light Green Most stable, transparent and durable
    The problem that I'm having is finding a place online where I can tell which is which - all the companies seem interested in doing is putting the product up and the price, with no descriotion, surface colour or anything, expecting YOU to know which is which and what works best.
    Obviously I know to get the top brands as the lesser known are just the top ones' discsb at B grade or below, but what I'm really concerned with is the recordable surface/dye type, for sake of longevity. I'm wondering if anyone knows where I can find out what's good, lasts longest, what dye formation or colour the discs are etc.?
    Any pointers would be MUCH appreciated!
  2. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,348
    Livingston, Scotland
    +227
    Groove
    I buy all my blanks from here :
    http://svp.co.uk/
    They tell you who manufactures the disc and what dye is used
  3. mjn
    mjn
    May 24, 2001
    22,067
    Herts, England
    +9,805
    Why not leave the house, and go into the shops themselves ? :confused:
  4. SyG
    SyG
    Apr 24, 2005
    138
    Kenny, thanks - I can figure out exactly what I need. A company that knows what it's doing!
    mjn, finding a place with a wide range where I live rather than a load of B or C quality discs is a mission, and when you go in any of these shops, everyone's stare burns into the back of your head until you buy something. Plus, I'd only go to look; it's so much cheaper online.
