How to know whether or not an Amp has a true phono stage?
Discussion in 'AV Receivers & Amplifiers' started by sugarmagnolia, Jan 4, 2019.
  1. sugarmagnolia
    sugarmagnolia
    Jan 2, 2019
    33
    9
    England, United Kingdom
    +3
    Some amplifiers I come across on eBay have an input labelled ‘phono’, but I know that sometimes it isn’t a true phono stage and therefore still needs a preamp to go with it. Is there anyway of telling if it’s true or not?
  2. gibbsy
    gibbsy
    May 17, 2007
    12,367
    3
    Cwm Cynon, De Cymru
    +6,690
    Apart from doing a search on Google or indeed contacting the customer service department of the manufacturer you would be taking the seller at their world. It is a fair assumption that the amp would have a phono unit if labelled as such, otherwise it would be a simple line-in connection needing a pre-amped TT.
