How to install Operator CAM Profile on Samsung Q90R TV
MarkySparkSurrey
Does anybody know how to install an Operator CAM Profile on a Samsung Q90R TV?
I'm using the built-in TV tuner of my 55" Samsung Q90R TV for regular terrestrial TV. But I'm also using the satellite tuner, in order to receive French TV from an operator called Fransat. I use a CAM CI+ module, as it's not free-to-air. It had been working OK. But I was trying to tweak some of the settings on my TV, and I deleted the Operator CAM Profile. I'm sure I did this at least once in the past, and after I turned the TV off and on again, it then just eventually prompted me to accept the Fransat Operator CAM Profile after the TV had been turned on for a while. But it's not proposing to install this Operator CAM Profile, and I can't find anywhere in the settings to force it to re-install the Operator CAM Profile. I've done a complete factory reset, but it's still not detecting the Operator CAM module. When I select one of the French satellite TV channels, I get an error message saying "CI+ module or smart card not found. Please check it has been inserted correctly".
cuke2u
Have you tried removing the module, I don't have much knowledge if they can be hot plugged, the turn on the tv, then back off and plug the module in then the tv back on again?
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
