How to install HBO GO on model 65UH615a
bornitz
Hi, How do I install HBO GO on a 65UH615a? I looked under premium content and Apps & Games and cannot find it. Although it’s an older model, I keep the software up to date. Thanks in advance, Bonnie
shotokan101
bornitz
Right and mine is a UH61 model (I believe the actual numbers after the model will vary) and I do have WebOS 3.0.. so I still don't understand why I can't find it. Thanks.
jwsg
I would suggest you ask on AVS forum as we're more familiar with UK spec gear and apps
shotokan101
Should be on the LG content store apparently.....
shotokan101
shotokan101
Have you checked that your TV is set to usa as country?
Similar threads
